turbo size?
Old Sep 12, 2008 | 10:47 PM
rxspeed7's Avatar
F-IT
turbo size?
so i was looking at some new options for a turbo, right now i have a stock port 13b-re motor with a microtech, hks log manifold and enough fuel to set florida on fire. the turbo i have been using for the past year and a half is a precision 6776e with a .60 a/r comp housing 66.7 inducer 84 exducer and a p trim turbine with a 84 inducer and a 76 exducer in a ..68 turbine housing. now ive gone threw 2 motors on this setup with a mazsport tune(also bought the turbo from scott at mazsport). now i dont like to get into turbo sizing stuff because it makes my head hurt but, everyone else i see has a huge turbine housing compared to mine and still has full boost at around 4 grand. so my question is would a .81 housing better suit my motor and have less back pressure but still spool fast?
the last dyno numbers i had were 330 at 14psi, and the car is primarily used for autocross and spirited driving. so a big laggy turbo is not an option. and help is greatly appreciated. zack
Old Sep 13, 2008 | 10:52 AM
Aaron Cake's Avatar
Engine, Not Motor
Wow, that's a small turbine. And probably why you've fried two engines.
Try .96 if it's available as a minimum.
Your turbo is not exactly a well suited autocross turbo either...
Old Sep 13, 2008 | 01:49 PM
rxspeed7's Avatar
F-IT
why would you say thats my motor prob. too much backpressure pushing hot air back into the cylinder? how much more laggy would a .96 exhaust housing make it? before i was getting full boost(14psi) at around 3200rpm and id like to stay in that area
Old Sep 13, 2008 | 01:53 PM
dean23's Avatar
pwned
ive always thought it was the combination of the compressor and turbine thats creates lag, nt the size of the turbine alone.
Old Sep 13, 2008 | 02:35 PM
Eclipsed4ever's Avatar
Surely a lot of the back pressure is dictated by the flow of the exhaust?
Old Sep 13, 2008 | 02:58 PM
Turbo II Rotor's Avatar
Who Shot the Sheriff?
That exhaust housing cannot flow enough air and it's creating high pressures and heat in your engine, turbo manifold and turbine housing.
Old Sep 13, 2008 | 06:56 PM
Aaron Cake's Avatar
Engine, Not Motor
What he said. High backpressure, high EGTs.
That sounds like a large compressor. A bigger hotside will help it spool. However a compressor that size isn't exactly an autocross turbo.
Old Sep 14, 2008 | 02:23 PM
rxspeed7's Avatar
F-IT
sweet thank you guys a lot. i guess im in the market for a new turbine housing.`
Old Sep 14, 2008 | 04:07 PM
Rx7TyreBurna's Avatar
Becoming pure track...
I am confused. Your rotary engine has cylinders? How?
Old Sep 15, 2008 | 02:35 AM
rxspeed7's Avatar
F-IT
sorry meant to say pushing hot air back into the housing?
Old Sep 15, 2008 | 02:10 PM
Turblown's Avatar
Turn up the boost
You should have a completely different turbo, not just a bigger turbine housing. The compressor is too large for what you are doing. Move way down to at least a 61mm...
FD7KiD
15
Feb 26, 2021 10:12 PM
C. Ludwig
Jan 30, 2019 06:31 AM
dkwasherexd
May 27, 2017 04:51 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
