smells like gas??
Old May 9, 2002 | 12:04 PM
crossbar17's Avatar
smells like gas??
when i first start my car and it runs it smells like gas, and my exhaust is always carboned up...could i have leaky injectors? is that causing the smell, also what causes the carbon is it the premix i have been running??
CB
Old May 9, 2002 | 12:08 PM
PraxRX7's Avatar
hmmm...
your O2 sensor or your Air Flow Meter could be out of whack causing you to run hyper rich...
Does it idle funny? Take a hand whif of the exhaust and see how rich is smells. (Could also be spark plugs old not burning the gas entirely...again strange idle would probably be a symptom.)
Old May 9, 2002 | 12:15 PM
Raymr's Avatar
If the smell is from the front of the car, check all the fuel hoses around the engine very carefully. Mine had a pinhole leak that would 'disappear' once the engine warmed up. Usual warning about pulsation damper applies too.
Old May 9, 2002 | 12:24 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
Yeah, check the ol pulsation damper, i was at jukyard yeasterdday and the one engine that was in the rx's we saw had its pd scew backed out
Old May 9, 2002 | 11:55 PM
crossbar17's Avatar
pulsation damper? where is it?
CB
Old May 10, 2002 | 12:41 AM
Ryde _Or_Die's Avatar
CB
Its like under the upper intake if I remember correctly. Someone showed me a pic on here before. If I had my NA still I would go look and tell you exactly but with my TII I have this lid on my engine bay(I/C)
ls1swap
Jun 3, 2024 03:25 PM
userjh5174
Alternative Fuels
Jan 9, 2016 08:49 AM
Aramir
Oct 18, 2015 02:39 AM
musker
Oct 1, 2015 05:58 PM
