Haltech No Rpm!
Old Jul 21, 2008 | 07:23 PM
calicrewchief's Avatar
RotorHead
No Rpm!
I do have 12v to the trialing coil pack during cranking. I'm not getting any rpm idication on the engine data page. Could someone draw up a scetch of exactly how the trailing coil should be wired?
89 TII
E6X
stock
Old Jul 21, 2008 | 07:33 PM
C. Ludwig's Avatar
www.lms-efi.com
Are you getting an RPM reading on the ECU datastream on your laptop while you're cranking it?
Old Jul 21, 2008 | 07:36 PM
RotorHead
No, nothing. When I turn the key to ignition on I get a slight stutter from the stock gauge and the haltech reading goes up to 63 rpms for a second.
Old Jul 21, 2008 | 09:55 PM
classicauto's Avatar
Crash Auto?Fix Auto.
How is your CAS wired?
What are your gain and filter settings?
Old Jul 21, 2008 | 10:22 PM
RotorHead
God damn it!!! I was so close! I found this thread and it f in started. https://www.rx7club.com/showthread.p...ghlight=no+rpm. So I started at a trigger angle of 70 and a trigger and home gain of 1. I would try and start it. Nothing and each time I would increase by one on both and crank it. I made it to f in 5 and finally got rpm on the data page. Then on six I was getting fuel and spark. Real rough and I could tell the timing is totally off. But for about five seconds it ran. I ended up running the battery dead. I put the charger on it and went and made some adustments and F#*^. I can't replicate what I did. For a second time I didn exactly what I first did and now nothing again. I am so f in pissed. I was ready to get a timming light and zero that bitch but no. Man I am gonna have a good hangover tommorrow.
But, thanks a ton Claudio RX-7! You are the man for sharing your info. Its so helpful to have guys like you to share info with everyone living in the middle of nowhere.
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
eplusz
15
Oct 7, 2015 04:04 PM
Einheri
Oct 7, 2015 12:23 PM
musker
Oct 1, 2015 05:58 PM
