when is it time for a rebuild?
Old Jul 10, 2008 | 04:04 PM
RXzeben's Avatar
so how does your engine tell you when its getting close to the time when it needs new seals?
Old Jul 10, 2008 | 04:54 PM
ArExSeven88's Avatar
id love to know this answer too
Old Jul 10, 2008 | 05:24 PM
celbii's Avatar
jackie chan > chuck norri
when it wont start anymore.
Old Jul 10, 2008 | 06:48 PM
drugblock12a's Avatar
WON'T FORGET DAVE
when you do a compression test and are unhappy with the results.......or if you just got some money to spend.
Old Jul 11, 2008 | 06:37 AM
Banzai-Racing's Avatar
Rotary Specialists
A few indicators:
Hard to start
Floods easily
Excess smoke
Excess oil consumption
Coolant loss
These may all be symptoms of other things wrong, but are also indicators of a weak engine. Easy one is compression test, below 80 psi it the engine is hard to start and floods easy.
Old Jul 11, 2008 | 06:59 AM
◡ KUZU◕7◕'s Avatar
¯\(°_o)/¯
when the "rebuild time" warning light lights up. ...
Old Jul 11, 2008 | 10:54 AM
Nick_d_TII's Avatar
When you have coolant or apex seals coming out of your exhaust... Its time for a rebuild.
When you car smokes soo bad your neigbors call the Fire Dept... Its time for a rebuild.
When you have to pull the egi fuse to deflood and it still doesn't start.... Its time for a rebuild.
When you have to push start your car because the egi fuse trick didn't work... Its time for a rebuild.
When you rx sounds like a tractor cause its running on one rotor... Its time for a rebuild.
When your car eats as much coolant as gas... its time for a rebuild.
Old Jul 11, 2008 | 12:41 PM
hatemy7's Avatar
Rotary
Originally Posted by Banzai-Racing
A few indicators:
Hard to start
Floods easily
Excess smoke
Coolant loss
and my fav, when ur driving and you hit the gas and you see is smoke and its not coming from your tires lol...
Old Jul 11, 2008 | 01:13 PM
kutukutu1's Avatar
All beautiful and helpfull answers. lol
Old Jul 11, 2008 | 03:04 PM
hungryhippolw's Avatar
This comment made Miss Vickie's Jalapeno chips fly out of my nose.
Old Jul 11, 2008 | 03:42 PM
RXzeben's Avatar
THANK GOD!!! im safe for now then!
Old Jul 12, 2008 | 03:25 AM
boost_its_what_for_dinner's Avatar
RotoriousRx7
OMG!!!!!!!!!!!
so funny yet so true. happened to me 3 times 2 n/a's and the O.G. t2 motor i had before the landers build. it sounds so mean but goes absoloutly no where.
funniest thing ever though was after i popped the t2 motor i actually got it to boost like 6 psi and it pulled like a stock n/a motor.....
Old Jul 12, 2008 | 08:24 AM
jackhild59's Avatar
Rotary $ > AMG $
Any time you ask a question on this forum about compression or coolant seals or overheating, you will get a chorus of *Jr. Apprentice Rotary Rocket Engineers* pop up to tell you 'It's time for a rebuild!"
If I had a buck for every time the chorus sings, I would have enough $ to have a Landers rebuild-but of course, I don't need one...do I?
Old Jul 26, 2008 | 01:36 AM
junito1's Avatar
F**K THE SYSTEM!!
Originally Posted by boost_its_what_for_dinner
OMG!!!!!!!!!!!
I can second the 6psi on one rotor. But i had a bad injector plug. Not a popped rotor.
Th0m4s
Feb 26, 2019 02:04 AM
incubuseva
14
Sep 3, 2015 12:37 PM
ncds_fc
Aug 15, 2015 10:06 AM
