holley 450 cfm on stock 12a
Old Jun 6, 2008 | 09:48 PM
jfeliciano15's Avatar
ROTORICAN
can anyone tell me if a holley 450 cfm is a good idea for a stock 12a with road race headers and will the stock fuel pump be enough?
Old Jun 6, 2008 | 10:39 PM
Siraniko's Avatar
RX for fun
of course but upgrade your fuel pump
Old Jun 7, 2008 | 08:21 AM
Alak's Avatar
You dont need to upgrade your fuel pump, but you should. Just remember a regulator when you do.
Old Jun 7, 2008 | 08:44 PM
rxtasy3's Avatar
u'll need 6psi for the holley. just buy a 6psi pump and u wont need the extra cost of a regulator. it's what i use.
Old Jun 7, 2008 | 09:15 PM
Alak's Avatar
I bought my Holley Fuel Pump and it came with a complementry regulator.
We also ran a Supercharged 12A with a 570CFM Avenger on a stock fuel pump for about 10 years with no problems.
Old Jun 8, 2008 | 11:34 AM
Jeff20B's Avatar
Lapping = Fapping
That must have been one tiny supercharger. Or the setup made less power than stock because the stock fuel pump is inadequate for even a stock carb but useable if you're not leaving it floored for very long.
Old Jun 8, 2008 | 02:54 PM
orion84gsl's Avatar
My 7 is my girlfriend.
It'll work, but get a Sterling instead.
Old Jun 8, 2008 | 09:32 PM
Jeff20B's Avatar
Lapping = Fapping
Lots of people like the Carter fuel pumps . They're just kinda difficult to install in a 1st gen due to the shape. I found a spot for mine, but it is slightly tilted. Works fine though.
I'd say a Sterling will beat a Holley every time, simply for the tuneability, not to mention power, but I don't have a Sterling to play with at the moment. If however you have your heart set on a big aftermarket carb on a Racing Beat manifold, get an Edelbrock. From what I've seen of mine on the Camden, it is EFI-smooth and very pleasant to drive, even with an aluminum flywheel. Others who've used them NA really like them too. You don't often read as many positives about Holleys, whether supercharged or NA, but you do see a lot for the Sterling.
Old Jun 8, 2008 | 10:22 PM
ROTORICAN
Thanks to everyone for the feedback including the parrot.
Old Jun 8, 2008 | 11:17 PM
Alak's Avatar
I concour on the edelbrock carbs. They are the cats *** for reliability and drivability. I ran one for awhile on an FC converted to carb. Worked better than the EFI.
Jeezus's Avatar
Stu-Tron Get Yo Groove On
600cfm user here.
Old Jun 9, 2008 | 12:24 PM
Sterling's Avatar
Nikki-Modder Rex-Rodder
Originally Posted by Jeezus
600cfm user here.
...Which is why you're slower than a Toyota Tercel.
Old Jun 9, 2008 | 12:30 PM
84stock's Avatar
I really really like the edelbrock 500 thunder series for any rotary, the 450 (465?) holley racing beat kit is also very good but tuning for the edlebrock holds better and is easier, and as for the sterling, I think this carb is a piece of
art and would highly recommend it for any 12a application.
Old Jun 9, 2008 | 03:49 PM
orion84gsl's Avatar
Hey, Tercels can be fast too......... if you swap in a 12A with a Sterling
Old Jun 9, 2008 | 04:46 PM
Jeezus's Avatar
Lets see, I have taken a late 80's 525, a new jeep, chrysler 300 V6... I am some Tercel!
http://www.youtube.com/watch?v=j1n_4MtdK-c&NR=1
Old Jun 9, 2008 | 04:57 PM
teddyrx2's Avatar
One Luv "Till The End"
Holley blue tap fuel pump and regulator and the 450 carb headers and your golden bro...You will be fine...Put the regulator between 6 and 7 pounds...
The1Sun
Mar 18, 2018 11:08 PM
