how do you disable power antena, is there a harness or a wire you can pull??
Old May 1, 2002 | 10:45 PM
TainoIndian's Avatar
the thing only stays down when i completely shut off stereo...i have seen on most cars it only works with radio on when cd player runnin it is down also but my car it stays up when i got a cd playing...
how can i disable the antena or is there some sort of wiring required..
THANKS!
Old May 1, 2002 | 10:59 PM
Zoomspeed's Avatar
Re: how do you disable power antena, is there a harness or a wire you can pull??
THANKS!
you can try a new CD player. I dont' rember what my stock one did, but my alpine only puts the antenna up when I listen to the radio. Sorry, I can't help u with the wiriing.
Old May 1, 2002 | 11:02 PM
well...
i got rid of the stock cd player i now have an AIWA MP3/ CD PLAYER..? there is tons of wiring behind deck from all that BOSE CRAP!
silver93's Avatar
yeah, you can unplug it. open the hatch, pull up the plastic cover where the jack is, take the jack out, use a flashlight and you'll see the actual antenna coax running back to it. Along the casing of the antenna, you'll see a wiring harness - there are like 6 wires going into it. Thats it! push the tab and disconnect the harness.
i just did it to mine this past weekend. damn gear teeth are probably shot, and got tired of hearing the motor whine.
Old May 1, 2002 | 11:06 PM
Street King's Avatar
*** Bless Texas!
Mine comes up wether radio or cd player. Iam not sure how it works but if it bothers you just turn it off. Listen to the sweet noise of angry bees.
Old May 1, 2002 | 11:11 PM
if theres no other way..
if anyone has disabled it lemme know,,,,,,,,
i am thinking of just ripping it off and getting it refinished at body shop to make it look like it was never there.
Old May 1, 2002 | 11:52 PM
Zoomspeed's Avatar
Re: if theres no other way..
Thats exactly what I'm gonna do later this summer when I get my flares and a repaint.
Theres was actully a thread I on this a while ago. There is a built in internal antenna for the stock radio, thats why coming from the stock radio there are 2 antenna plugs. For aftermarket Head units you just us one of them and leave the other disconnected, the disconnected one is the internal antenna. If you can find a plug to connect the internal antenna to the after makret head unit then you can get rid of the external antenna all together. You probably won't get as good reception, but if your like me you rarely listen to the radio anyway.
I kinda rambled. If you need some clarifcation let me know.
Old May 2, 2002 | 12:43 AM
i like the radio in big cities
where there are plenty of stations to tune to but i live in colorado..?
nothing but a lot of interferance and dead air......so i have no use for it plus i am going to get that satelite radio a try heard good things so far...........
Old May 2, 2002 | 03:34 AM
7-sins's Avatar
thats not paint....
I have an AWIA head unit for now and it does the same thing. I think only high end units know weither the antenna should be up or not. I was thinking about running a toggle switch on the antenna wire, that way I can switch it to go up.
Old May 3, 2002 | 02:21 PM
R1 POWR's Avatar
i, too, have an AIWA (MP3/CD) player. it keeps the antenna up regardless of what's playing (radio or cd). your best bet is to do like 7-sins suggested. just put a toggle switch in-line with the antenna wire. it should be the blue wire (i think) from the head unit. if you installed the unit yourself, then you'll know which wire it is. check your AIWA install instructions -- it'll tell you which wire it is. another alternative would be (Zoomspeed's suggestion above) to disconnect the antenna wire (this would keep the antenna permanently down), then just switch the antenna plug on the head unit to the other plug in the car that goes to the internal antenna in your back windshield. the reception probably wouldn't be as good, but you could get rid of the stock antenna & plug the hole with a little body work. good luck.
Old May 3, 2002 | 02:28 PM
twinturboteddy's Avatar
Grumpy Lurker
Re: well...
I have the same player and the same problem!!!!!
it's irritating!!!!!!!
Damn Taino, we share a lot of interesting things on our cars.
Old May 3, 2002 | 03:25 PM
silver93's Avatar
TTT -
I sent you a PM about polishing and never heard back - did you get it?
Old May 3, 2002 | 04:32 PM
Grumpy Lurker
strange, send me another PM.
Old May 3, 2002 | 10:04 PM
i may try somethin else for now...
first i will try that wire i will look in the aiwa book and mess with the wires and try to disable it or toggle it......if not i will try doing a CD player swap with my friend to see if getting a higher end player fix that issue....
I will get back with you all and TTteddy i also will let you know what i did if i find solution....
i like this deck because its not too flashy and gets job done looks cool with the rest of my inerior....
Old May 3, 2002 | 10:10 PM
silver93's Avatar
TTT- sent you a PM -
Old May 3, 2002 | 11:38 PM
cafe's Avatar
Swap it with S2000 anttena
I did it. PM me if you want to know how
Old May 4, 2002 | 12:16 AM
duboisr's Avatar
garfinkle took his out ,had the hole covered and painted .He put an antena in the headliner also removed all emblems
streetlegal?
Mar 17, 2022 02:46 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
