help on emission
Old Apr 16, 2008 | 08:26 PM
galaxy convoy's Avatar
Undercover
Unhappy help on emission
I need help I just failed the emission test
Here's my result
HC crusie limit 160 cruise emmisions 287 fail
HC Idle limit 220 Idle emissions 998 fail
CO(%) cruise limit 1.2 cruise emission 0.37 pass
CO(%) Idle limit 1.2 Idle emissions 3.68
I havent change spark plugs and wires and O2 sensor. But I think HC and CO are way too high please help im just new on rotaries
Old Apr 16, 2008 | 09:34 PM
stylEmon's Avatar
FC since 99
turbo or na?
Old Apr 16, 2008 | 10:21 PM
Undercover
its a N/A 86GXL
Old Apr 16, 2008 | 11:02 PM
jackhild59's Avatar
Rotary $ > AMG $
Here's my result
You need minimum of a working 3way cat and an air pump.
Do you have both? It looks like your cat is shot.
Old Apr 16, 2008 | 11:24 PM
Undercover
I really dont know what the air pump looks like, but when I look at the engine I got only two belts installed one for alternator and for powersteering. How do I know if my cat is really bad?
Is it better to go emission specialist to work on my emissions? I really dont know what to do since this is my only car that failed the emissions.
Old Apr 16, 2008 | 11:25 PM
Delicious's Avatar
hook ur air pump back up, thats why ur idle is ****
you need another belt
Old Apr 16, 2008 | 11:33 PM
shadoe's Avatar
#1 RX7 Homo
Missing air pump=automatic emssions fail
Old Apr 17, 2008 | 09:25 AM
Undercover
It seem to be the my air pump has been removed, does anybody know where can I get one? thanks
Old Apr 17, 2008 | 09:33 AM
PvillKnight7's Avatar
clean your plugs, run your gas down to 1/8 tank, fill the tank with a bottle of gas line antifreeze, add a gallon of gas to mix it up. pass emissions...
Old Apr 17, 2008 | 10:21 AM
MmSadda's Avatar
^Pvill Knight's suggestion seems to be somewhat common. You want to make sure you drive it ONLY from the nearest gas station to the testing facility, 'cuz of risk of damage to your car.
Old Apr 17, 2008 | 03:43 PM
Forgot that part, thanks! Do what MmSadda said...refill your tank asap after the test.
Old Apr 17, 2008 | 04:52 PM
stylEmon's Avatar
FC since 99
thats why i prefer everclear... doesnt hurt the car to run on it.
the air pump will be on the other side from the ac and ps. kinda looks like a really simple alternator... kinda.
you should get BRAND new spark plugs, and a new cat. any old tire/muffler shop can put it on for you.
Old Apr 17, 2008 | 06:01 PM
everclear? like the grain alcohol? never thought of that...
Old May 21, 2008 | 09:29 PM
Undercover
Since I didnt passed emissions and dont even know what's missing on the engine bay. What else do i need to put my emission back. except for the air pump since I already got that part but not install yet. here's some pics
Old May 21, 2008 | 10:51 PM
wtf, do u premix? did u even try what we suggested?
Old May 21, 2008 | 11:41 PM
Undercover
I havent try anything because I got some starting problems before, but now my car starts fine already. I premix my car also. emissions has been removed and i dont know what emission parts do i need to put in besides the air pump. I know this thread is a month old, but starting problems suddenly appear before i try all of your suggestions.
Old May 22, 2008 | 03:44 PM
misterstyx69's Avatar
Retired Moderator, RIP
The Air Pump,the BAC(ACV) valve and the Six port actuators,..are all gone out of your Engine Bay..Essentially you have no Emission Stuff on your Engine.,.Try to Find somebody that is close to you,that has a BONE STOCK car.you can look at it and Compare your car to theirs.That way you can get a good idea as to what it needs..otherwise you are Trying to Ask Guys on forum to Take their Wildest Guess as to What you need..like Trying to Kill a Cloud!.
ls1swap
Jun 3, 2024 03:25 PM
Snook
Feb 27, 2021 02:54 PM
PinkRacer
43
Oct 1, 2015 09:13 AM
RedBaronII
Sep 20, 2015 11:29 AM
