no spark!!!!!!
Old Apr 21, 2002 | 01:17 PM
MazdaRx7Power's Avatar
no spark!!!!!!
ok i have a spark plug tester and i put it on my bottom plugs and the bottom right doesnt spark. i put it on the bottom left and it sparks but blinks every once in while. so that would mean that the coil is messed up right?? also probably going to the junkyard tommorrow can i use any coil from any 2nd gen or does it have to be 86-88???? do you guys think that the spark plug tester is accurate enough???
Old Apr 21, 2002 | 01:32 PM
HAILERS's Avatar
HAILERS
I don't trust any new fangled thing. Take your TRAIL PLUG WIRES OFF(upper wires). Start the car. Does the car run normal?????? Any rx will run as normal as can be with just the lead (lower) plugs operating. If the plugs or the coil were really bad, then the car won't start or will shake and roll and wobble etc.
Old Apr 21, 2002 | 01:33 PM
thats what it was doing.... it would start and start to shake and wobble and bam shuts off.
Old Apr 21, 2002 | 01:36 PM
ok i went outside removed the top plugs and the car just turns, also the rpm's werent moving. when the rpm's dont move is it that its not getting gas or getting spark????
Old Apr 21, 2002 | 01:46 PM
HAILERS's Avatar
HAILERS
The rpm gauge works off the trail coil, so thats why you did not see anything. Now try this. Put the top plug wires back on (trail) and pull the bottom wires off. Does the car start? And run more or less without shaking and rolling. I'll stick around for another thirty or so minutes.
Old Apr 21, 2002 | 02:03 PM
did that and the car wont start!! it might be flooded now since its been turning off and on..
Old Apr 21, 2002 | 02:14 PM
HAILERS's Avatar
HAILERS
Yeah, probably flooded now. Oh well. Maybe it is the coil. If it turns out to not be the lead coil and you buy another one, I might be able to buy it from you if you don't spend too much on it. I have a project that could use another lead coil. There is a THING about the lead coil where if you only have one wire hooked up it will not fire due to its using the other wire to complete the circuit, therefore not spark with only one wire hooked up. Also the coil assy itself needs to be bolted down making a good ground on its chassis. That does not seem to be your problem, just threw that out there is case you get the new coil and just lay it on the fender. I guarantee it won't spark like that, without it being bolted down. By the way, something I missed on this problem. Is it that the car was stumbling and thats what made you start to see if the plugs were working? I'm trying to say that if the trails were working properly, the car will run just on them, just a bit more sluggish than if the leads alone were working. Just a thought.
Old Apr 21, 2002 | 02:33 PM
well i went to the store yesterday and car stalled so had my friend help me tow it with his car which we broke a chunk of his frame and got pulled over. hahaha but today i had that plug tester and the top plugs would spark but not the bottom ones. it would spark everyonce in a while.
having my bro go to the junkyard and try and find me one tommorrow... also can i use a coil from any other rx-7 like any 2nd gen???
Old Apr 21, 2002 | 02:41 PM
HAILERS's Avatar
HAILERS
86 to 92 are the same. Here is my source for that http://www.mazdatrix.com/ign-1.htm . I was serious about buying it from you if you find out you don't need it. Good luck.
Prediict
32
Nov 18, 2015 08:41 AM
Aramir
Oct 18, 2015 02:39 AM
tctwaites
Sep 22, 2015 08:48 PM
