S4/5 differences?
Old Nov 23, 2007 | 06:36 PM
Slow Rotor's Avatar
FC3S
Question S4/5 differences?
Hey guys ive never really been able to find the exact info but what are the actual differences between the 2, has anyone got a list?
Old Nov 23, 2007 | 06:51 PM
I love pop-up lights's Avatar
The Assistant
The only ones I know are cosmetic and power differences, they have different tail lights, the trim on the s4 is black as opposed to painted on the s5, the s4 LSD is a clutch type and the s5 is a viscous (if the car even has an LSD) the s5 makes more power I don't recall the exact numbers and I'm too lazy to look it up but it's like a 15-20 hp difference IIRC. There is some other stuff that I don't know or can't remember at the moment but I think you can find all the differences in the FAQ or by utilizing the search button.
Old Nov 23, 2007 | 06:53 PM
Slow Rotor's Avatar
FC3S
Yeah i knew about the tail lights and interior. Some one told me that the ecu's were different? And reading another post there it said there were better oil cooler lines in the s5. There seems to be a heap of little things just wondering what there are.
Old Nov 23, 2007 | 06:55 PM
melicha8's Avatar
Mazdaspeeding
Here is all you can handle. Pages and pages of info
https://www.rx7club.com/search.php?searchid=4293149
Old Nov 23, 2007 | 06:57 PM
The Assistant
oh yeah the OMP in the s4 is mechanical and the one in the s5 is electrical I beleive, also the aux ports on s4 n/a's are activated by back pressure from the exhaust and the s5's are activated by an air pump
Old Nov 23, 2007 | 07:03 PM
Slow Rotor's Avatar
FC3S
That didnt really help that much, im jsut after a straight up list with all the differences
Old Nov 23, 2007 | 07:31 PM
The Assistant
sorry I couldn't be of more help that's all I got, I can search around as well and try to compile a list but it could take a little while...
Old Nov 23, 2007 | 07:37 PM
CoCoBitzz's Avatar
-1
use search tool dude.
Old Nov 23, 2007 | 08:06 PM
Slow Rotor's Avatar
FC3S
Ummn i already have and as i said above, couldn't really find what i was after
Old Nov 23, 2007 | 08:52 PM
dial8's Avatar
Registered User
What specifically are you looking for? a list, comparo, spread sheet? I can tell you officially, from Mazda's PR, HR, and HUD here in Cali all even Series are good successful platforms, but odd numbered series are doomed to fail. Repeatedly. Till the end of time. Period.
Old Nov 23, 2007 | 11:44 PM
farberio's Avatar
NASA-MW ST4
S5
- Electrical OMP vs S4 Mechanical OMP
- 10 blade mechanical fan (maybe 12...) instead of 8 (maybe 10)
- Radiator Filler is different
- ECU is different, car is very rewired
- Knock Sensors
- 9.7:1 NA and 9.0:1 TII vs S4 9.4:1 NA and 8.5:1 TII
- You already got bumpers/moldings
- Intake Manifolds are different, I know for sure N/A has VDI
- N/A Aux Ports 'pull' to open instead of S4 'push'
- Rotors are lighter then S4 (Therefore flywheels are different)
- S5 is GTUs vs S4 GTU
- S5 irons are supposedly beefier in one little important spot
- S5 Aluminum Housings have different Spark location (I think leading is a bit lower)
- I THINK primary ports are a bit different. (The ones on the middle iron)
I'm sure there are others, I am certainly not an expert.
Old Nov 23, 2007 | 11:48 PM
specialop's Avatar
stitch
rotaryresurrection.com has a great list of differences plus mechanical knowledge.
Old Nov 23, 2007 | 11:52 PM
staticguitar313's Avatar
R.I.P. Icemark
They cut cost on s5s, the quality is just not the same. Crappy auto seatbelts, plastic sway bar links, steel rim for spare tire, steel jack instead of aluminum, terrible wiring, heavier car, fill point for cooling system isn't at the highest point like s4's and the upper water pump neck is plastic, RPM sensitive power steering instead of speed sensitive like s4's warning light surround doesn't look like it fits just right, no grey interior option, ackward shirt ****, water temp gauge is useless . . . there's more and i'm forgetting it, i've owned 1 s5 and 3 s4's i prefer the s4's no matter what, its easier to put s5 taillights and trim on an s4 than to try and fix all that bull$h!t!
Old Nov 24, 2007 | 12:14 AM
mazda.junkie's Avatar
Freebasing mountain roads
I know for a fact that there has GOT to be at least 500 threads on this topic somewhere. I see about two a month at least! Anyway's, maybe we can get a MOD to sticky this "coveted" information. Maybe someone needs to start an official thread. I totally agree that the S4 is as good as an S5 in almost every way.
My 87 has never been outrun with a n/a S5. I have had 3 FC's, 2 S5, 1 S4. I kept the 4, but I would prefer the S5 turbo over the TII.
Old Nov 24, 2007 | 12:30 AM
arghx's Avatar
rotorhead
we should add a list of these differences to the FAQ.
Old Nov 24, 2007 | 12:36 AM
That would make it easily accessible to the noobs, and a refresher for the veterans. There is a truckload of info in the stickys that Icemark put at the top of the 2nd gen forum, that is all it lacks. Include little things like the fact that the S4 has a 2 spoke steering wheel and the S5 has three.
Old Nov 24, 2007 | 04:14 AM
R.I.P. Icemark
s4's with s5 trim and s6 alternator FTW!!!!! ^_^ plus they are more plentiful
Old Nov 24, 2007 | 12:41 PM
13b Alchemist's Avatar
IMO s5 look better hands down int and ext. But everone is forgetting although it was a heavier car the 89-91 had better performance 160hp vs 138hp NA 182hp vs 200hp turbo
86-88 offered non power racks
FYI engine speed sensing is better
Old Nov 24, 2007 | 01:10 PM
Macrophobic's Avatar
poor
wikipedia has got some of the technical changes and history but alchemist has covered it for the most part, you just have to look at the cosmetic differences to see which ones you prefer. If there was a weight gain im sure it was minimal compared to the power gain.
Old Nov 24, 2007 | 07:28 PM
Cleva Locc Dogg's Avatar
Maniac 7
s5 rotors got higher compression, and overall engine is better engineered... handling more rpm's and producing a lil more power
Old Nov 24, 2007 | 07:34 PM
You must have forgotten that the S4 n/a has 146, not 138.
Old Nov 24, 2007 | 07:46 PM
phoenix7's Avatar
for the guy that can't search:
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/differences-between-s4-s5-138961/
at RX7 addict!!!!!
Old Nov 25, 2007 | 04:27 AM
Slow Rotor's Avatar
FC3S
Ok well for us noobs i think this site really needs a sticky thread with all the differences listed. I have had my car for over a year now and i love rx7's but ive never really seen the information anywhere. If there was a comparison chart it would make it easier for people to decide between an s4 or s5. I keep hearing lots of little bits of info from reading threads (ie s5 has better oil cooler lines) but never see a comparison. And once again reading that thread that you posted doesn't cover everything.
Old Nov 25, 2007 | 12:35 PM
dial8's Avatar
Registered User
There is one, its called the FAQ! If you READ the whole thing, you'll FIND the differences. Whats the big deal, you guys didn't have Silent Sustained reading in 4th grade to teach you good reading habits. This is all you need to know:
S4 N/A: Slow until you put money into it, Best looking of the bunch
S5 N/A: Slow until you put money into it
S4 Tii: Overrated stock, slow until you put into it
S5 Tii: Overrated stock, slow until you put into it, Hard to find
Shainiac
Jul 17, 2019 02:20 PM
Spirit Rx-7
Mar 14, 2016 12:36 PM
Captain Hook
Sep 22, 2015 01:12 PM
Ian_D
Sep 6, 2015 10:38 PM
