Power FC Connecting PFC w/o cutting 4 wires??
Old Oct 11, 2007 | 03:41 AM
SHALUV639's Avatar
Post Reader
Has anyone tried connecting the PFC without cutting the 4 wires? What do you think would happen, if anything?
Just wondering......
Old Oct 11, 2007 | 05:04 AM
scrubolio's Avatar
they don't understand
search...get dale clark's guide...someone has done it before and its not good, if you don't want to cut the wires, then you can pull the pins out of the harness with the wire still in tact (search for a guide), or you can just cut off the pins on the PFC itself, your choice
Old Oct 11, 2007 | 07:26 AM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
Mine is running with all the pins. but most of the stuff the pins use to control are gone. Also mine was a Auto before i modded it.
Old Oct 11, 2007 | 08:35 AM
TEZTnTUNE's Avatar
BUILD, TUNE, RACE, REPEAT
u can crimp on male and female spade connectors. that way rewiring back to stock for diagnosis is simply reconnecting spade terminals. also color coat them egr=green on ecu side as well as harness side. it will help avoid coonfusion later on.
Old Oct 11, 2007 | 09:59 PM
zinch's Avatar
i was going to pick up a harness from autosportwiring.com for my pfc
Old Oct 11, 2007 | 10:15 PM
DarkLikePoe's Avatar
It's dark like Poe.
Just pull the pins on the PFC.
Old Oct 11, 2007 | 11:39 PM
cewrx7r1's Avatar
Eye In The Sky
If you look in the manual and determine what the pins control, and if those devices are not on your engine; then there is no need to cut them.
Time for you to do some research.
Old Oct 13, 2007 | 09:45 PM
twilsonbpa's Avatar
i installed mine with pins intact and had a strange idle bounce when the car reach a certain temperature. (temperature at which the fans are to come on) I cut the wires and now the car runs great.
Old Oct 14, 2007 | 09:43 AM
cewrx7r1's Avatar
Eye In The Sky
The more modified an engine is, normally the less or none of the pins need to be cut. Read my first post on this thread. Do what I mentioned and you will learn something. I even have previously posted what they control.
Old Oct 15, 2007 | 09:37 PM
puma's Avatar
canadian monster
on a stock engine with all emissions, i have seen that also, when fans would come on, idle would start to hunt. Stopped when we cut the wires.
Old Oct 16, 2007 | 05:07 PM
Stix37867's Avatar
Got Rotors?
Nothing bad happens if you don't cut them. Two things happen. First is you have an picky idle. It'll bounce around sometimes, other times it's normal. Second thing is that the E/L (electrical load) detector is always on. This partly causes the picky idle.
Donald Hampton
Sep 1, 2015 03:41 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
smikels
Aug 18, 2015 01:26 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
