What size AN fittings and hose for oil cooler?
Old Apr 8, 2002 | 02:26 AM
Indo Audio's Avatar
Hey there, I am replacing the oil cooler lines, what size AN fittings and hose do they use? I am going stainless, one hose is ripped, and might as well replace it into a one piece stainless!
Thanks,
Old Mar 6, 2003 | 02:44 PM
rallimike's Avatar
I'd like to know, too.
Old Mar 6, 2003 | 04:23 PM
Rx7aholic's Avatar
It is very hard to firgure out what mazda size fitting oil lines are, Also are u planning to use the stock oil coolers? Cause if so u will find it very difficult to find the right an sizing fitting to mated with the stock oil cooler. Also u can but the mazdatrix oil adapter to run your custom oil lines, I think it's like $10 each adpaters.
Old Mar 6, 2003 | 05:50 PM
maxcooper's Avatar
WWFSMD
I don't know the stock sizes, but AN10 works well as a replacement.
You can get hose and AN fittings from many places.
Mazdatrix has the best prices that I know of on metric-to-AN fittings so you can connect to the front housing and oil filter pedestal. They also sell pre-fabbed SS lines that you can just buy and install.
I am not sure how to connect the SS lines to the stock coolers, but you could replace them with Mocal or other standard coolers. The stock driver's side (U.S.) cooler has a built-in thermostat. If you replace that cooler, it is wise to include a separate thermostat in the system. Mocal makes several, and you can get them from pegasusautoracing.com.
Rotaryextreme.com sells a few different kits that have all (or at least most -- I don't know the details of these kits) the parts you need.
-Max
Old Apr 20, 2007 | 05:16 PM
ALNY93R1's Avatar
Does anyone know the size of the oil cooler thread and the connection at the oil filter pedestal thread, were the banjo fitting goes?.. I think it's 18mm, but by what 1.5?..
Old Apr 20, 2007 | 07:52 PM
Howard Coleman's Avatar
Racing Rotary Since 1983
https://www.rx7club.com/showthread.p...+coolers+cheap
i didn't use dash 10 as the other lines are smaller so what's the point... dash 8 is the ticket.
hc
Old Apr 20, 2007 | 07:56 PM
ALNY93R1's Avatar
hc
Thank's for your help
Old Apr 20, 2007 | 10:48 PM
Scrub's Avatar
bow leggin'
If you're interested I can build you a kit incluiding all the lines, fittings and some brackets for around $250 for steel braided or a litle less for the push on style fittings.
-Dan
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
