fun with ABS....
Old Apr 7, 2002 | 04:05 AM
Scott 89t2's Avatar
SOLD THE RX-7!
fun with ABS....
ok got a bunch of stuff done last week. and yesterday when the car rolled a few feet after starting the abs light comes on which makes it not work. noticed something very strange today. started car, pushed brake pedal (not moving) and ABS came on, you could feel it in the pedal as I was stoped. I could do make it happen over and over as I pressed the brake... I got out and pulled the fuse... hmm, what would cause it to come on? speed sensor? voltage problem?
what was done last week.
removed all of rear brakes and hubs to install toe bushings and hawk pads. changed front pads/rotors, SS brake lines, bleed brakes. but also took out alternator to change the water pump. I've heard of voltage/power problems causing weird things. so I'm not sure if this has something to do with taking the brakes apart or the alternator and wires around it...
doh
Old Apr 7, 2002 | 04:16 AM
I wish I was driving!
seems a little useless to ask you... but when you bled the brakes, did you then follow by bleeding the ABS?
Sean
Old Apr 7, 2002 | 08:33 AM
No7Yet's Avatar
Hmmm... did you make sure to reconnect all the wheel speed sensor gears and stuff?
Brandon
Old Apr 7, 2002 | 12:50 PM
peejay's Avatar
Old [Sch|F]ool
If the light comes on after you start rolling, it's most likely a wheel sensor problem. Make sure all sensors are plugged in and the air-gap is corrent.
Old Apr 7, 2002 | 02:09 PM
Scott 89t2's Avatar
SOLD THE RX-7!
Sean
yes
thats what I thought after the first day. but I'm not sure how that would cause the abs to start working with the car stoped??...
the FSM doesn't go into the abs at all, it just tells you how to use the factory abs code checker tool...
Old Apr 7, 2002 | 06:59 PM
Scott 89t2's Avatar
SOLD THE RX-7!
nobody knows anything about abs?
Old Apr 7, 2002 | 08:00 PM
Erik's Avatar
Best of both worlds
maybe i was interpreting it wrong...but are u saying that when the ABS light is ON in the light cluster, its no longer working? my light goes on and off periodically...but i don't notice too much difference in the pedal or stopping...
Old Apr 7, 2002 | 08:09 PM
rx7_turbo2's Avatar
Professor D.P
Scott
While I have no explanation for the problem i can tell you your not alone. I was sitting idling in the driveway one day and the ABS kicked in, I could feel it pulsating through the pedal. It lasted for 30sec then stopped, and never did it again.
Old Apr 7, 2002 | 08:14 PM
chatch's Avatar
Do all Turbo II's have ABS? Is it worth keeping and how much work is it to yank it all out? Im wondering if I could clean up my engine compartment a little.
Matt
88 T2
Old Apr 7, 2002 | 08:20 PM
rx7_turbo2's Avatar
Professor D.P
No not all turbo II's have ABS, and I think it's kind of a pain in the *** to dissable the system properly.
Old Apr 7, 2002 | 10:19 PM
Bambam7's Avatar
I came, I saw, I boosted.
I would get rid of it.. but anyways...
If the ABS is going on whenever you press the pedal, the computer thinks the wheels are locked up, ei- Not moving, therefore, it's not getting a voltage pulse from the sensor.
I would say it's almost for SURE the wheel sensor, check the wires for the actuall sensor, and make sure the sensor didn't get knocked away from the rotating ABS wheel on the hub.
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
