Wolf 3D Discuss the Wolf 3D Engine Management System
Wolf 3D Maf
Old Jul 31, 2007 | 01:43 PM
pilot's Avatar
Maf
Does anybody know about using a MAF sensor with a Wolf V4+? The PC software manual (version 1.016) says that a MAF can be used, but it´s the only thing that says about it.
What kind of signal does the Wolf accept coming from the MAF?
What type of sensor can be used? (hot-wire, Karmann-Vortex, etc).
Thanks a lot in advance.
Old Jul 31, 2007 | 01:55 PM
hwnd's Avatar
watashi no shichi
..i'm no help here but i do want to ask "why maf"?
Old Jul 31, 2007 | 02:47 PM
nyt's Avatar
nyt
you can program the wolf to accept any load input sensor pretty much.
Why you'd want to run a maf when it has a built in map sensor is beyond me.
Old Jul 31, 2007 | 03:16 PM
pilot's Avatar
In my opinion (and in many people´s too) a MAF is the best system to determine the amount of air entering the engine. It has the inevitable charge loss, but it can be minimized pretty well in some cases.
Does the Wolf accept a variable frequency signal? or just a variable voltage one?
Regards.
Old Jul 31, 2007 | 05:23 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
I belive it only takes GM type maf's which are voltage iirc
Old Jul 31, 2007 | 06:45 PM
pilot's Avatar
That´s what I imagined.
If anybody has tried using a MAF, please comment here.
Thanks for the info, regards.
Old Aug 1, 2007 | 12:34 AM
nyt's Avatar
nyt
If you use a maf, you just need to calibrate the voltage output to the load table like any other sensor.
Old Aug 1, 2007 | 06:14 PM
pilot's Avatar
Nyt, are you aware that not every sensor has a variable voltage signal? There are some with variable frequency output.
R|©ha®d
Sep 24, 2015 11:39 AM
mulcryant
Sep 9, 2015 05:24 PM
