ITS caster, toe, camber...your thoughts
Old May 20, 2007 | 11:26 PM
bean13's Avatar
Question ITS caster, toe, camber...your thoughts
So, just want to see what other guys are running. Mine are stock specs with the exception of camber, -3.5* in the front and -1* in the rear....what do you folks perfer.
I am on hoosiers as well, '90 ITS.
Ludwig...any thoughts?
Old May 21, 2007 | 06:36 AM
C. Ludwig's Avatar
www.lms-efi.com
You'll need to play with the settings and monitor your results with a tire pyrometer. You're in the ballpark. Something around -3 - 3.5 in front, -1 - 2 in the back. All the caster you can get while making them even. I always ran 1/8" total toe out in front and 0 toe in the rear. When I told Mike at ISC how the car was set up as far as alignment and shock/spring package he asked "How do you drive that thing?" Quite well actually, but your results may vary.
Make use of the tire probe. As you begin to use more of the tire you'll probably find that you'll need more camber to maintain even temps. Some tracks require different setups too.
Old May 21, 2007 | 09:57 AM
j9fd3s's Avatar
Community Builder
ours was closer to zero toe, but other wise about the same....
Old May 21, 2007 | 05:02 PM
bean13's Avatar
max caster huh? Would you reccomend that for "baseline"?
Old May 21, 2007 | 05:33 PM
j9fd3s's Avatar
Community Builder
actually paulie and i were talking about this the other night, we're thinking we had the car too low, and the geometry would have been better with a higher ride height.
any thoughts on that?
Old May 21, 2007 | 07:03 PM
C. Ludwig's Avatar
www.lms-efi.com
Think we got 8* caster. It's a poor mans source of camber gain in turns. With the kingpin layed back the more you turn the wheel the more camber gain there is.
I think you're right on the ride height. I had some big problems when lowering the car too much. The rear was very funny about ride height. You can get it low enough to bottom the trailing arms on the tub. When you do that everything goes to hell. Also, in the front you'll run into bump steer problems when going seriously low. As it is the IT rules limit you to a specific ride height. Was it 5" at the rocker? That's really close to as low as you want to go. Maybe too low.
Old May 22, 2007 | 10:55 AM
j9fd3s's Avatar
Community Builder
i remember measureing it, but in like 03.... i wanna say the race car was like 23" from the ground to the top of the wheel opening?
the drift car and street cars got setup higher, like 24.5", which isnt too far off stock
Old May 22, 2007 | 12:37 PM
wrankin's Avatar
Old Rotary Dog
The 2007 GCR sets minimum ride height as 5" to the bottom of the rocker panel (not including the welded seam). This is with driver out.
-b
renjiv2
57
Jan 25, 2024 03:34 AM
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
rotor_veux
Sep 28, 2015 09:25 PM
