2nd Gen Air Flow Meter help!
Old Mar 22, 2002 | 03:58 AM
turbozetusa's Avatar
Exclamation 2nd Gen Air Flow Meter help!
Is there any way to remove the air flow meter? I am installing and aftermarket intake and I don't have room to keep the air flow meter. Help Please! What are my choices if any?
Old Mar 22, 2002 | 08:15 AM
Grimlock's Avatar
Thumbs down No can do!
ZERO!!! NADA!!!! ZILCH, unless you get a stand alone computer like the Haltech. the stock ecu needs the reading from the afm in order to run. you take it out and the car wont even start.
Old Mar 22, 2002 | 11:44 AM
turbotwista's Avatar
No AFM no run
Old Mar 22, 2002 | 06:57 PM
NZConvertible's Avatar
I'm a boost creep...
Re: 2nd Gen Air Flow Meter help!
You mean you're trying to fit a Turbo Zet? Can't wait to see this one...
Old May 20, 2002 | 06:19 PM
RX7GT's Avatar
...must be a conspiracy
While on the subject, does anyone think it will be possible to remove my entire drivetrain and bolt a couple of these turbozet things to the rear and use them like a jet engine?
Old May 20, 2002 | 06:28 PM
RETed's Avatar
Haltech - I can get one for you for $1,200.
-Ted
Old Feb 11, 2003 | 07:31 PM
Well, I am sorry that I did not post anything sooner. I did manage to mate the airflow meter to the twin turbo zet by fabricating an aluminum plate. I used pvc and rubber couplings along with a 6inch K&N cone air filter. The verdict? 3 runs before installation, 3 runs after installation. Average 1.2 second drop 0-100mph! Thanks for the advice guys!
Old Feb 11, 2003 | 07:45 PM
Scott 89t2's Avatar
SOLD THE RX-7!
did you have the stock intake before??.... adding the k&n probably made the whole diff....
Old Feb 11, 2003 | 08:16 PM
HAILERS's Avatar
HAILERS
What be a Turbo Zet?????
Old Feb 11, 2003 | 08:26 PM
nonameo's Avatar
**-P I drive a miata.
I am assuming it is an aftermarket intake manifold for turbo 7's
Old Feb 11, 2003 | 09:20 PM
Scott 89t2's Avatar
SOLD THE RX-7!
no it's probably one of those plastic turbos you buy off ebay for $40...
Old Feb 11, 2003 | 09:22 PM
nonameo's Avatar
oh. in that case, 1.2 second drop is not bad for 40$$
Old Feb 12, 2003 | 02:15 AM
It's one of those stupid little electric fans you stick in your intake...
Old Feb 12, 2003 | 10:56 AM
Crionics's Avatar
LOL...Like the tonado?
Old Feb 12, 2003 | 11:15 AM
HAILERS's Avatar
HAILERS
Hmmm. What if I got a *smart little electric fan*? Never mind.
Old Feb 12, 2003 | 12:29 PM
Jimmy325i's Avatar
No longer cares
Turbozet needs the whistle tips so people know to move into the slow lane as he comes screaming up behind them. "It's like an alarm clock. Wooooooo Wooooooooooo!"
On second thought. 1.2 seconds could be accounted for in the reduction of fuel in the tank after three consecutive hard runs to 100. (in otherwise stock trim)
Turbozet, What are these times that you had for the 6 timed runs you made?
Old Feb 12, 2003 | 12:30 PM
rotarygod's Avatar
Rotors still spinning
A 1.2 second drop 0-100 huh?! Hmm....your name wouldn't happen to be Michael A. Pool would it? Check out this website for the details on this guy...http://www.scottmurrish.com/subaru/turbo-zet.html A certain Michael A. Pool on this website claims EXACTLY 1.2 seconds 0-100 in 2 entirely different cars! One of them being a 2nd gen RX-7. Here's a better website on that product. I love this one!!! http://www.autospeed.com.au/cms/arti...ml?&A=0237&p=3 Go sell your product elsewhere!!! We aren't falling for it. Who would use the name Zet in their screen name if they weren't selling it?
Old Feb 12, 2003 | 01:28 PM
autocrash's Avatar
Now with more 1st Gen!
lol.... gotta love new uses for cheap computer case fans.....
Old Feb 12, 2003 | 02:38 PM
Jimmy325i's Avatar
No longer cares
30% increase in power AND gas mileage.... WOW It makes free power! lol
I wouldn't use that thing to blowdry my nuts.
Old Feb 12, 2003 | 03:33 PM
J-Rat's Avatar
Alcohol Fueled!
Wow... Yet another useless thread about e-chargers....
Old Feb 13, 2003 | 03:16 AM
A couple of my favourite quotes from the esteemed Mr. Poole...
"The Turbo Zet was not designed to provide "boost". It was designed to intelligently regulate the airflow to the engine to provide an ideal fuel to air ratio across the RPM range. Better yet, it would save gasoline, help my vehicle run smoother and last longer by eliminating carbon deposits, and allow me to drive up and down in elevation without changing fuel grades or adjusting my intake."
Intelligently regulate the airflow? Eliminate carbon deposits?
"How do the Turbo Zet and Twin Turbo Zet work? While the MECHANICAL turbo charger and supercharger were developed to increase engine power by supplying additional air and pressure to the engine thereby increasing power and reducing pollution, the TZ and TTZ are small, electronic versions equipped with a NEC microprocessor, servo motors, impellers, and electronic drivers. The microprocessor's sensors reads engine RPM, air pressure, air temperature, and alternator impulse, analyzes all the input data, and directs the servo motors to rotate and supply the right amount of air to the engine at every specific instance/RPM for optimum combustion efficiency.
All this for just $35...
"By adjusting the volume of air to an ideal air and fuel mixture ratio 14.7:1 at every instance possible in order to achieve perfect combustion thus maximizing engine power, fuel savings, and reducing emissions."
Now that's the scary one. Can you imagine what would happen if the mixture was 14.7:1 at full load?! You'd have a blown engine before you even got to redline! Of course I highly doubt this thing can actually have any effect on mixtures, so I'm sure you'll be quite safe...
This guy obviously knows nothing about engines. He's just another snake oil peddler.
Old Feb 13, 2003 | 09:34 AM
nonameo's Avatar
..... I thought he meant for 0-60~~~
0-100 1.2 second drop is not so great.
13
Jan 9, 2018 11:19 AM
rotor_veux
Sep 3, 2015 07:10 PM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
