12A half bridge - remove exhaust sleeve?
Old Mar 25, 2007 | 10:47 AM
Bruceman's Avatar
Rotor Power Rules
I'm not so concerned about street driving with this engine because its main purpose is autocross in the SM2 class.
I've widened the exhaust port to within 0.5 inch of the side and have brought the lower edge down to to create a D shape with the straight side at the top. I wasn't sure how far down I can remove material so I cut open a scrap housing through the exhaust port. Exhaust sleeve is removed.
Now I can see how far to lower it without getting in to the coolant passage. This is the standard 12A exhaust port.
After doing this the exhaust sleeve seems to be more of a hinderence than a help. If I grind the sleeve to match it to the new width and earlier opening the sleeve becomes very thin. I don't think it is going to help the flow. Should I throw them away?
Old Mar 25, 2007 | 02:19 PM
Kim's Avatar
Kim
OBEY YOUR MAZDA
*Right clicks - saves picture in tech folder*
They also isolate the housing from the hot exhaust gasses.
Im willing to believe that running without them could raise the operating temperature of the engine.
Old Mar 25, 2007 | 02:37 PM
slo's Avatar
slo
registered user
are you going to port all the way up to the top of the port? I don't think that overhang would be very good for flow.
I bet you could get away with removing them, but coating the inside where the sleeve went with some kind of ceramic heat barier would be a good idea, maybee the 2000+ degree jet hot coating. You would also need to fill the sleeve pin hole, but thats no big deal.
Old Mar 26, 2007 | 11:58 AM
Kenku's Avatar
spoon!
No, you don't need to fill the pin hole; it's blocked by the irons. Some sort of ring is nice at the end of the port where it meets the header though; where the flange of the exhaust sleeve was, otherwise the transition's even more abrupt than it would be.
I dunno how much you want to lower it though.
Old Mar 27, 2007 | 04:41 PM
diabolical1's Avatar
temperature would be my concern as well, but i do know many have run race engines without the sleeves. i've seen them. i suppose a coating could work to keep temps "normal", but if it did become a problem, increased cooling volume should work just as well, right?
Old Mar 27, 2007 | 05:56 PM
slo's Avatar
slo
registered user
if not filling hole I would be woried about exhaust possbly breaking down the outer o ring over long periods of time. Maybe its of no real concer.
Old Mar 28, 2007 | 02:40 PM
rotarygod's Avatar
Rotors still spinning
The mfr peripheral port housings don't have sleeves. They are just aluminum. Heat gets rejected by the coolant system which is why they don't melt.
I like this cross sectional cutaway. It demonstrates very clearly why I made new sleeves for the 13B.
Old Mar 29, 2007 | 12:59 PM
j9fd3s's Avatar
Community Builder
yes it does!
Old Mar 30, 2007 | 08:35 AM
jgrewe's Avatar
GET OFF MY LAWN
I like that cut away as well. It goes good with the 13B rotor I cut up. Anybody want to see a 13B housing hacked apart?
Old Apr 4, 2007 | 11:52 AM
Bruceman's Avatar
Rotor Power Rules
Thanks for the replys
I decided to keep the inserts and matched them to the ports.
Old Apr 4, 2007 | 01:46 PM
RXBeetle's Avatar
Hey Bruceman,
Nice cutaway. On my 13B I tig welded a bead at the edge of the sleeve. This gave me some meat to play with using a dremel and a carbide bit. I just kept grinding/fitting till I had just a thin gap between the housing and the sleeve and a very nice transition.
Oh yeah I'm just up the road from you. If you need any machining or shop stuff done let me know.
Old Apr 5, 2007 | 02:13 PM
j9fd3s's Avatar
Community Builder
the gap is there between the sleeve and the rotor housing for air injection...
Old Apr 10, 2007 | 12:18 AM
2a+RoN's Avatar
I removed the sleeves and made new aluminum ones in my 1/2 bridge REW. Temperature difference is minimal. Hottest it would get prior to removing the sleeves was about 82* C. Now the highest I've seen is 83.5* and its getting pretty damn hot here in AZ..
Old Dec 14, 2007 | 03:57 PM
Latin270's Avatar
Any long results from running w/ no exhaust sleeves. Pros/ Cons?
Old Dec 15, 2007 | 10:31 AM
2a+RoN's Avatar
I've been daily driving my car since April w/ the above sleeve setup. No problems whatsoever with overheating, and even in the summer when ambient temps are 115*.
Old Dec 15, 2007 | 11:19 AM
BASTARD's Avatar
I ran a N/A 12a streetport with a similar exhaust port as 2a+RoN's without a sleeve at all... the car was my daily driver for over 2 years and saw 8k, 9k and even 10k weekly if not daily in all weather climates from 29-108 degrees.
The motor never missed a beat and ulimatly was torn down due to a oil pressure problem that was the result of a breech in the front cover/plate oil galley.
Old Dec 18, 2007 | 09:24 AM
Latin270's Avatar
Sweet. So it is an option to remove these things w/ no adverse affects. Cool!
Old Dec 23, 2007 | 11:09 AM
mikewoodkozar's Avatar
Brap, Brap, Ole!
Dang Bastard, did you build that motor?
Old Dec 26, 2007 | 06:29 PM
Did you have the rotors clearanced, lightened, and/or balanced? I'm working on a custom peripheral port 12a and will see 9k often. I'm definitely going to have the clearancing and balancing done. I'm considering the lightening.
Old Dec 26, 2007 | 11:59 PM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
Just adding something to this
You only want to port the D shape (With the Stright edge on top) with turbochargers.
The early opening helps spool the turbo
If you are going to run it N/A you want to open later so you use every little bit of the exhausts power before it leaves the motor.
Also the more square the opening is the louder it will become.
Just my .02
Old Dec 27, 2007 | 12:54 AM
BASTARD's Avatar
I was 15 at the time and it was my first motor...my older brother did most of the work. we spent days breaking down over 10 motors to get the best parts we could find. Back in those days the only companies around were Rotary Engineering and Racing Beat. The GSL-SE was just coming out in showrooms and no one knew what an RX3 was
we assembled the motor on a stump in the back yard and after firing up the motor for the first time it smoked like a chimney. we figured it would have to be rebuilt again but i drove it for a few weeks anyhow. Then one morning I fired it up and the smoke was gone
anyhow that motor ended up lasting for over 2 years and heard the buzzer almost everyday.
the motor made great power from about 5k all the way up to about 9k. anything above 9k was just to keep the revs up
the only thing done to the motor was porting. The motor was rebuilt with all used parts with the exception of the gasket and o-ring set.
12a's rev a lot better then 13b's and if you balance everything then there is no reason you shouldn't be able to have a super reliable pp motor. the only issues the pp motors have are the blocking of the water jacket. after a while they just start leaking coolant
the large square ports have been known to work the apex seals pretty hard. if you plan on building a motor to last a long time I wouldn't go as big as the one pictured above. The rounding of the closing edge is to help releve the flexing of the apex seal
yes... they get very loud and raspy with a port like that
Old Dec 27, 2007 | 02:17 AM
Rx7_Nut13B's Avatar
Well most people think that the apex seal flexes because of the square opening, but the flex is from opening up the exhaust (Side-to-Side) and not leaving enough metal on both sides. If you square up the top and bottom and don't touch the sides much there is no problem with flex.
Old Jul 27, 2011 | 11:24 AM
indio84's Avatar
who else here is running with no exhaust sleeve
Old Jul 27, 2011 | 07:36 PM
user 893453465346's Avatar
Red Pill Dealer
I believe a big part of the bowing of the apex (steel) seal is due to the blast of exhaust moving across it when the port opens. Take a torch to a piece of steel laying on a bench and pay attention to which way it curls. This is why ceramic is superior.
Old Aug 20, 2011 | 05:14 AM
bumpstart's Avatar
talking head
ive done them with and without the insert,, D ports with flat up, D ports with flat down, early open and late close,,
i have done the shop templates,, and even evolved my own over many progressive changes
you name it,, i gave it a crack ( well maybe not the roo tail port ! )
i have seen nil ill effects on any housing from running sans insert,, beside maybe a slightly hotter running engine
IMO
taking the insert out allows you options of moving the floor or roof further
and allows you to take out the reversion step and get a straight floor if you wanted so
to get the best from them ,it will sometimes require you to bell mouth or port match the extractors or turbo manifolds
i find the D port with the flat down allows you to follow the natural shape of the casting ( sans insert ) a little better
and the rounded close ports are certainly quieter , and interact with carbs better
i see few advantages in having the D the other way around,, beyond having exacting overlap period
i find the big square ports suit turbos as they have best surface area for the port timing
and you can control the exhaust/ inlet overlap period better with the straight close
they are louder,, and in turbo engines if you take them wider
there is large gains in TQ across the majority of the rev range to be had for minimal changes in port timing
how much you get away with will depend on the revs and the type of seals you use
i have had nil issues with +5 mm wider each side and mazda seals
here is a few examples,, just to show i have given all types a go
cristoDathird
28
May 30, 2019 08:47 PM
dkwasherexd
May 27, 2017 04:51 AM
Leeroy_25
Aug 17, 2015 12:53 PM
rx7brandon
Aug 16, 2015 10:55 AM
