Plug wire locations!!!!!!
Old Mar 15, 2007 | 06:31 PM
fasso's Avatar
Hi i just bought this 91 rx7 non turbo and i dont think the plug wires are in the right places so if anyone could tell me which goes where that would be great i tryed searching and nothin helps.
Old Mar 15, 2007 | 06:35 PM
killinit937's Avatar
well l1 and t1 go to the first rotor
and l2 and t2 go to the second rotor...
simple... trailing spark plugs go on top? leading ones on the bottom?
here it is simple... blue plugs & wires on top and black plugs & wires on bottom
Old Mar 15, 2007 | 06:45 PM
fasso's Avatar
a picture would help a bunch
Old Mar 15, 2007 | 06:54 PM
icecreaman's Avatar
your ignition boxes actually SAY 'T1' 'L1' etc.... i even think that is also on the block. its not hard.
Old Mar 15, 2007 | 07:08 PM
87 t-66's Avatar
not a drifter
are you serious?
Old Mar 15, 2007 | 09:44 PM
fasso's Avatar
ya i was serious i dont know much about these cars and i am tryin to figure out why it wont run right i got the plugs going on right thanks for the help but it still barely runs.
Old Mar 16, 2007 | 01:09 AM
NZConvertible's Avatar
I'm a boost creep...
The leading coil is at the front of the engine bay, and is marked L1 and L2.
The trailing coil is at the rear of the engine bay, and is marked T1 and T2.
The front rotor is #1.
The rear rotor is #2.
The trailing plugs are the top ones.
The leading plugs are the bottom.
It doesn't get much simpler.
If you want a picture look in the Factory Service Manual. If you don't have the FSM, click here and download it in PDF format for free.
Old Mar 16, 2007 | 09:50 AM
Loki101's Avatar
If it barely runs, that could be a couple of things. If I were you, Id check out the FSM and look at the trouble shooting section and go down the list. Just a suggestion
The1Sun
Mar 18, 2018 11:08 PM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
Snoopy FD
Dec 8, 2015 01:45 PM
