Difference between DBB?
Old Feb 25, 2007 | 01:36 PM
SaTxRx-7's Avatar
What's the difference between normal tubros and DBB, I've tried to research the forums here about dual ball bearings but I haven't found to much.
Old Feb 25, 2007 | 02:04 PM
turBRO240's Avatar
Certified Rotorhead
DBB "Dual Ball Bearing" turbos have just that.... ball bearings.
for example the turbo wheels obviously sit on them for turning. The ball bearing design is like 2 cirlces... one bigger and one smaller and small ***** in between to reduce friction when turning.
its the same as a bearing on a skateboard... or suspension system of a skateboard........ theres the truck (axel for skateboards) then the bearing goes on... and the wheel on top of that.
heres a couple of good links that will show you examples.
http://science.howstuffworks.com/bearing1.htm
http://science.howstuffworks.com/bearing3.htm
on turbos... theres dual ball bearing or journal bearing. DBB is usually about 8% faster in spooling (someone can correct me on the number... but its close)..... so a DBB turbo would spool up roughly 300-500rpm quicker than a journal bearing turbo.
on garrett turbos... the "R" at the end of the turbo model number means that its a DBB.
for example.... a GT35R is DBB, but a GT3574 is not.... btw the "74" is the turbine size or "exducer"
on HKS turbos..... the TO4R and TO4E are journal bearing and the TO4Z is DBB
generally the DBB turbos cost just a little more than journal bearing turbos.
- Artin
Old Feb 25, 2007 | 02:16 PM
SaTxRx-7's Avatar
I did a notice link while snooping around that had different dyno graphs with different turbo setups, and I noticed a difference in the spool time with DBB...Turbos.
But your explanation cleared it up so much more. The break down of the different model of tubro's to know which are dual bearing helps a lot to.
Thanks.
Old Feb 25, 2007 | 02:46 PM
turBRO240's Avatar
Certified Rotorhead
lurking around the single tubro section for a while will answer alot of questions in the future.... but if you have anymore just PM me
Old Feb 25, 2007 | 08:40 PM
Generally DBB turbos cost quite a bit more than journal bearing turbos, like $500 or so.
Old Feb 25, 2007 | 08:49 PM
CarbonR1's Avatar
Ball bearings are more robust as well. They can handle thrust and radial loads much better than conventional brass journal bearings.
They have about 6% better turbine efficiency in transient response, but only about 3% in steady state conditions.
The ball bearing cartridges are one of the most expensive parts in the whole turbo.
Kevin
Old Feb 28, 2007 | 02:48 AM
fastrotaries's Avatar
W. TX chirpin Monkey
To date it's you can't buy just the center section. You must purchase the entire turbo. Which makes it an expensive initial proposition.
Old Feb 28, 2007 | 03:21 PM
SaTxRx-7's Avatar
Thanks for all your input, it's appreciated. Right, no unfortunately I don't have an FD3 at the moment (18 wheeler hit mine 12 - 10 - 06) and I'm looking at purchasing another this year.
Some of the cars i'm interested in come with the single conversion and a dbb turbo, I just want to be as informed about them as I can be.
Although with 7s, it seems there's so much to know, being prep'd for everything is almost impossible unless you acheive the title of Guru j/k... Kudos to those who are there . I'm glad I learned about this community it's really helped me learn a lot.
Shainiac
Jul 17, 2019 02:20 PM
Spirit Rx-7
Mar 14, 2016 12:36 PM
Captain Hook
Sep 22, 2015 01:12 PM
Ian_D
Sep 6, 2015 10:38 PM
