Far East Forum Serving Asia and surrounding Areas. Far East users, post event and club info here
Help would be very appreciated (Description)
Old Nov 27, 2006 | 11:41 PM
RX7SP's Avatar
rotary addict
I have picked up this V-mount description a while back and would like to have the writting translated since I am doing this set up in my FC
Thank you
(Arigato)
J-P
Attached Thumbnails Help would be very appreciated (Description)-ntnsracing_1801_255010485.gif
Old Nov 28, 2006 | 12:36 AM
Circuit Theory's Avatar
japan connection
there is actually a mistake on that diagram.
the blue box is the I/C obviosly that is the intercooler.
the green box is says it is the radiator but based on the diagram the green box is much smaller than the pink/red box which I assume should be the radiator.
blue is I/C
Green is A/C condensor
pink/red is Radiator
under the pink(radiator) is the electric fan/fans
behind the blue (I/C) is the battery
the last bit on there is the Air seperator panel to divide air between the lower half and upper half. The kanji is to small to read but i can see the #3 on there so I assume that the air seperator panel can or should be adjustable in three different ways depending on how you set up is working so that you can give more air to one of the two halves. That is a pretty simplistic layout, if you are planning to do this kit on your own you will not really need this diagram. Actually you definately will not need the diagram. It seems that this diagram was just a random brainstorm of someones. The most helpful information from this diagram is maybe identify to someone who was not sure where to place the condensor unit.
Good luck with your V-mount set up! I think keeping the A/C is a great idea for the FD guys that want to have V-mounts but most of the FC guys don't really care to keep their AC badly enough to get all new lines fabricated for it.
Hope that helps
Tom
Old Nov 28, 2006 | 05:18 PM
RX7SP's Avatar
rotary addict
Thank's Tom
I had deducted (logicaly) most of what you explane. I just wanted to confirm my logic thank you.
As for the A/C that is just it
Even if this is an FC I am getting to old and do not want to cook in the car (to hot)
I want the performance but need the comfort so I will go that extra to get it
By the way this set up will be in a 88 FC but I retrofitted with a 13B-REW TT
Again thanks for your help my japanese is not that great even after being in your country for 2 1/2 months in Koroiso
arigato
komban-wa
J-P
Old Nov 28, 2006 | 09:25 PM
DaiOni's Avatar
Wankler
it's not a random brainstorm - it's a simplified diagram from HKS. According to them, they tested all the other v-mounts on the market, combined this with their own R&D, and came up with this idea as the optimum design.
Old Nov 28, 2006 | 11:15 PM
RX7SP's Avatar
rotary addict
I think the design is great I tend to agree with HKS as for the A/C condenser I was wondering if keeping it close to the rad was an obligation but having it angled a little makes a lot of sense for the flow
J-P
distr0
Canadian Forum
Oct 7, 2015 08:17 AM
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
musker
Oct 1, 2015 05:58 PM
93FD510
Oct 1, 2015 02:00 PM
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
