Wut In Da World Is Goin On Here?!?!?!
Old Nov 12, 2006 | 12:44 AM
playa_made_rx7's Avatar
Angry Wut In Da World Is Goin On Here?!?!?!
ok so im driving home from my grandmas house in my 87 Rx-7, come to a stop, and my car cuts off. Not only did it do it once or twice but 5 freaking times!!!! wut in the hell is going on with my car????
Old Nov 12, 2006 | 12:45 AM
tandolla's Avatar
check TPS ohm's and is this a NA or TII..
Old Nov 12, 2006 | 12:48 AM
RXnos1200's Avatar
1200 gone......but......
vaccum leak? will the engine stay on if you keep giving it gas?
Old Nov 12, 2006 | 12:49 AM
tandolla's Avatar
oh yea DUH!! i didnt even think of a vacum leak.. yea check for VAC leaks..
Old Nov 12, 2006 | 01:27 AM
Madrx7racer's Avatar
has the fuel filter been replaced ever? did it stall or LOSE ALL POWER? make sure your TID or Intake tube are not loose or cracked/broken..........
details would be nice......only women are psychic.......i can't get in your head.....
Old Nov 12, 2006 | 01:28 AM
if i keep it revved yeah the engine will stay on and i believe its a NA cuz i know it doesnt have a turbo.
Old Nov 12, 2006 | 01:29 AM
well it just completely shut off. no power whatsoever and when i tried to start it back up it took like 5 minutes
wait.........so you lost the battery too?
Old Nov 12, 2006 | 01:30 AM
what is a TID
Old Nov 12, 2006 | 01:31 AM
Turbo Inlet Duct...it's in the FAQs.....you're NA so don't worry about it
Old Nov 12, 2006 | 01:33 AM
yeah the battery lost power for a second then all the lights would turn on but no fire on da engine
Old Nov 12, 2006 | 01:36 AM
check the battery terminals and cables for damage, then go over the grounds over the whole car......check to see for damage on the ECU wiring harness and wires........
what happened when you tried to turn the car on ( noise-wise)
Old Nov 12, 2006 | 01:37 AM
where exactly is the ECU? im a noob on these cars. now put a chevy in front of me and im a ok
Old Nov 12, 2006 | 01:38 AM
it gave on click for a second then when i tried startin it it juss kinda cranked without a fire
Old Nov 12, 2006 | 01:43 AM
RXnos1200's Avatar
^^^ check all your connections. make sure there is no corrosion on the battery terminals and a good ground and have good contact.
ECU is under the carpet on the passenger side up against the lower part of the firewall
read this.......lemme think.
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/frequently-asked-questions-2nd-generation-rx-7-faq-fc-494667/
Old Nov 12, 2006 | 01:46 AM
ok thanks man
RXnos1200's Avatar
looks like you might have several issues. go through all the suggestions given and see what happens. good luck
Old Nov 12, 2006 | 01:49 AM
ok......
1. check batt. terminals and cables
2. Check wires/ harness to the ECU.....then look for any heat damage to the engine bay wiring.....( search for any exposed wires that may be grounding out)
3. go to a kragens( aka Checkers in some parts of the country) and have them do a recharging system check ( they'll tell you if the alternator is dead)........or do it yourself
post in here after you do that^^^^
Old Nov 12, 2006 | 01:54 AM
learn to LOVE this:
86-88 FSM
89-92 FSM
96fd3s
38
Apr 19, 2021 06:50 AM
Coochas
44
Nov 5, 2019 11:08 PM
Sethix
Nov 3, 2017 11:48 PM
frosty1993
Sep 30, 2015 01:27 PM
