Water pump not working after 4k rpms?
Old Jul 24, 2006 | 09:18 PM
GT34's Avatar
Rookie Rotarhead
I'm going to drive a car back on the highway for a long period of time and my brother who's comming with me on the trip told that the water pump just spins and doesn't pump any water after 4k. I tried calling his bluff but I'm not sure now. He also told me the rotary's cooling system sucks on the highway for that reason. Can anyone back me up on this? We'll be driving for about 30hrs. But man it's so worth it. (picking up a 10ae, I've wanted one for so long!)
Old Jul 24, 2006 | 09:40 PM
1SxyRXy's Avatar
my fc broke
uhh ive never had a problem or heard of that. buti drove my TII in 100+ weather for over 4 hours once on the freeway and after 4k in 5th ur doing almost 90 or about that
Old Jul 24, 2006 | 09:44 PM
MazdaTed's Avatar
I have driven for hours atleast at 4K probably higher, with No problems.
I think your brother is right about the water pump not working, but I think that is only at really high RPMs, water pumps just churn up the water and not pump any (or so im told).
Old Jul 24, 2006 | 10:20 PM
liv's Avatar
liv
New User
4k in 5th should be about 105-110 in a n/a
so you'll be fine
but why not just buy a new waterpump?
Old Jul 24, 2006 | 10:38 PM
RETed's Avatar
I was going to say...
You're doing seriously illegal speeds if you're hitting 4kRPM in 5th gear...even in a Turbo II.
We're not talking about German autobahns, right?
Even from 60mph to 80mph, the tach should not be going over 3.5kRPM or so...
I don't know why you're worried about sustained 4kRPM driving?
-Ted
drago86's Avatar
It's not till like 6k or so, I forget its in the racing beat catalogue.
Old Jul 24, 2006 | 10:45 PM
misterstyx69's Avatar
Retired Moderator, RIP
I can See "Cavatation",but I wouldn't Bet that your brother is Neccessarily Right.The water Pump still turns...BUY a New Pump?..No...Slow Down..uh yes.If you are Doin 4K in 5th gear, You are Going Way too fast to be out on the Highway.Take it to the track.(congratulations on gettin a 10AE though!)
Old Jul 24, 2006 | 10:46 PM
Dcrasta's Avatar
Did u remove your thermostat? Thermostat is the restriction that helps prevent cavitation. Also dirty radiator (Bugs etc) can make it heat up on the 'highway' when u need that additional airflow.
Old Jul 24, 2006 | 11:05 PM
arghx's Avatar
rotorhead
if you remove the air pump and have a single alternator pulley then the belt can slip and that can cause problems at high rpms
Old Jul 25, 2006 | 03:49 AM
Dcrasta's Avatar
double post sorry.
Old Jul 25, 2006 | 06:29 AM
NZConvertible's Avatar
I'm a boost creep...
What a load of bollocks. Rotary engines have an entirely conventional cooling system, no different to what you'll find on any piston engine.
Old Jul 26, 2006 | 08:47 AM
My5ABaby's Avatar
Rotaries confuse me
He's jealous.
FD7KiD
15
Feb 26, 2021 10:12 PM
sherff
Feb 24, 2019 12:09 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
immanuel__7
89
Sep 5, 2015 10:23 AM
FD7KiD
Aug 17, 2015 11:50 PM
