can you put an s5 speedometer in an s4 cluster?
Old May 24, 2006 | 07:56 PM
royaltrex7's Avatar
can you like it says put a series 5 speedometer into a series 4 cluster and change out the guage backings as well as the bezel to series 5 so you run the more accurate guages from the series 4 and keep the series 5 160 speedo????? while keeping s5 guage styling. maybe repin the harness for the guage configuration of the series 5 so the guages would say and read the proper thing. or can you pull a broken rod for the needle out when it is broken into the guage its self?
Old May 24, 2006 | 08:03 PM
'87 turbo II's Avatar
Sleeper but still slow
Why do you want an S5 speedo? The Turbo models go to 160 my car is an S4 and it goes to 160. S4 or S5 doesn't meany anyhting other than style, go with S4 turbo guage cluster and get a apillar voltometer if you want (I didn't know the S4 guages are more acurate, unless someone wants to clear up some B.S.) or just get an S5 Turbo guage cluster and have the better styling, but using S4 cluset with an S5 speedo hybrid sounds like too much trouble and fabrication..
Old May 24, 2006 | 08:15 PM
royaltrex7's Avatar
well i have an n/a and i have 2 gutted cars a 91 and an 88 the 88 is great body and chasis with suspension, brake, rims, tire, exhaust, ect. upgrades swaping to s5 motor and like the full circle + i have white face s5 gauge backings both clusters are apart but the series 5 has a broke needle in both the fuel and temp guages. like the 160 speedo. and thus my problem. and my idea remove the screws from the speedos and swap them out. then change over the guage covers and the bezel. so i have the 160 speedo and look like s5 guages. and everywhere ive looked the s4 temp guage is more accurate not trying to bull **** so if any of this explains myself so i can get some advice then im happyish.
Old May 24, 2006 | 10:29 PM
Icemark's Avatar
the S5 speedo is smaller than the S4 version
you would have to use the whole S5 cluster and re-pin the S4 cluster harness
Old May 25, 2006 | 05:32 AM
wishIhadanFC's Avatar
i've swapped a bunch of components between s4 and s5 clusters, but not the speedo.
Old May 25, 2006 | 06:34 AM
royaltrex7's Avatar
so how did that work out for you?
and icemark i did notice the size but would it work if the black bezel with the clear cover work if i changed it?
Old May 25, 2006 | 10:54 AM
Icemark's Avatar
calibration would be the biggest issue, since you would be using a different needle.
With a different needle, there would be different weights to the needle.
Old May 26, 2006 | 07:45 PM
royaltrex7's Avatar
i mean undoing the speedometer from the board and then bolting it into the s4 but still using the same needle and everything
MazdaspeedR1
The Bad & Fugly Businesses
27
May 22, 2018 05:58 PM
OrangeMax
Sep 4, 2015 10:42 AM
rx7shirley
Sep 2, 2015 02:11 PM
