U.S fuel what octane u runnin
Old May 4, 2006 | 05:02 AM
don iz will's Avatar
hi all just wondering what octane you U.S boys are using in your cars. over here (aussie) we have 93 , 95, and shell and bp do 98 i use 98 bcoz as far as i know jap 7s are designed to run on 100. what are U.S 7s designed to run standard?
Old May 4, 2006 | 05:08 AM
RevUp13b's Avatar
zZzZzZzZzZz..............
i believe the manual says 87 .... for n/a you should use 87, for T2's i think theres a debate between using 87 or 91 for stock T2's, but modded T2s should use the highest octane possible.
I use 87 for the n/a and 91 for the T2
Old May 4, 2006 | 05:55 AM
Turbonut's Avatar
Different countries have some variation in what RON (Research Octane Number) is standard for gasoline, or petrol. In the UK, ordinary regular unleaded petrol is 91 RON (not commonly available), premium unleaded petrol is always 95 RON, and super unleaded is usually 97-98 RON. In the US, octane ratings in fuels can vary between 86-87 AKI (91-92 RON) for regular, through 89-90 (94-95) for mid-grade (European Premium), up to 90-94 (RON 95-99) for premium unleaded or E10 (Super in Europe)
When I purchased my '89 TII new in May '89, I used 87 which was the recommended rating. I continued to use 87 until slight modifications were done when the new engine was installed in 2001. At that time, and since I've used 93.
Old May 4, 2006 | 07:41 AM
thanks thats interesting when i lived in the uk they had 95 and 98 same here in australia and japan ive been told most manufacturers for jdm sports cars are designed to use 100 does the U.S have an equivalent to jap 100 ron?
Old May 4, 2006 | 07:43 AM
Wtf ^^ There Should Have Been A Gap Between Your Quote And My Writing
Old May 4, 2006 | 08:07 AM
rotorforce's Avatar
I'm back Bishes
I use 93 octane in all my rides...
Old May 4, 2006 | 08:14 AM
umi415's Avatar
AREN'T YOU SUPPOSE TO RUN AT LEAST 92 OCTANE ON A TURBO?
I USE 93 ON MINE
driftfc87's Avatar
DAYMAN
93 all the way
Old May 4, 2006 | 11:29 AM
Goofy's Avatar
If you can get 94 octane (There's one station around here that has it and it's about $0.25 more than 93), that's approximately 99 RON.
I use 89 on my N/A because I'm used to it. I use 93 on my scooter because it's so cheap. I'm basically a marketing ***** that believes Shell puts something useful in the higher octane gas.
Old May 4, 2006 | 11:48 AM
Icemark's Avatar
I just edited so that there now is...
You must have accidentially erased the "te]" from the [quote]
And I used 87 in all my non turbo motors (better burn quicker when compressed) and 91 in my Turbos.
Old May 4, 2006 | 11:52 AM
swbooking's Avatar
The Never Ending Project.
87 in the NA sport and 91 in the TII
Old May 4, 2006 | 12:53 PM
fcdrifter13's Avatar
Play Well
From: We're all fine here now, thank you. How are you?
as low as I can get it.
Old May 4, 2006 | 01:05 PM
Eternal_Gamer's Avatar
91 octane, I happened to find 92 here. I wish we had 93. i also use octane boosters when i have the money.
Old May 4, 2006 | 01:16 PM
jawillyrx-7's Avatar
93 octane in a modded 1991 NA any less and it runs like **** and doesnt get as good of gas mileage
Old May 4, 2006 | 02:01 PM
J-Rat's Avatar
Alcohol Fueled!
Ultimately, you want to run the lowest octane fuel you can get away with. Some later model cars have ECUs that are smart enough to advance the timing to a point just before detonation, when higher octane is introduced. Unfortunately, our ECUs arent really that smart. 87 for anything stock, and once you start modding, increase your octane as needed to keep up with your modifications. This applies more for the TIIs then the N/As
Old May 4, 2006 | 03:39 PM
jgrts20's Avatar
Who are you?
87 due to the high gas prices.
Old May 4, 2006 | 04:03 PM
Aaron Cake's Avatar
Engine, Not Motor
I've always recommended running low octane (87 in most areas) in the NA according to the manual, but one step up in the TIIs. Might have to go higher in the TII if you start modding.
Old May 4, 2006 | 04:13 PM
LAN's Avatar
LAN
Been using 87 for like 7 years now.
I don't have a massive turbo or anything crazy.
Any specific mods when to start increasing octane?
-Turbo Upgrade
-FMIC
-Boost Increase
-Etc.
Old May 4, 2006 | 04:16 PM
Jager's Avatar
Tear you apart
87
Old May 4, 2006 | 10:35 PM
royaltrex7's Avatar
i run 91-93 depends on what the store has you know. but full s5 swap and got a free turbo from work so time to do some modifying and premix (so im not sure maybe try out 2 gallons of nitromethane, and 4 ounces of 2 cycle with premium.) ill let you guys know how it goes
sherff
Sep 12, 2015 12:22 PM
SCinfidel
Sep 8, 2015 05:36 PM
whinin
Sep 5, 2015 11:52 PM
