Sponsored by: CARiD
Front E-shaft bolt
Old May 3, 2006 | 09:03 PM
dreadseb's Avatar
Front E-shaft bolt
Do any of you guys got any tricks that you have used to get the front eshaft bolt loosened out Im tryin my first rebuild here and the bolt is seized in there pretty tight. Im sure theres enough experience on this forum that Im hoping somebody will come up with something.
Old May 3, 2006 | 09:27 PM
13b4me's Avatar
You MUST heat it with a torch until it starts to glow... Then hit it with an impact driver (preferably 1/2")...
Old May 3, 2006 | 09:41 PM
dreadseb's Avatar
Thanks don't have any clue why I hadnt thought of that lol, and is the threading on it regular thread, or was mazda smart about that and set it up do tighten under the rotation of the engine and made it with left hand thread.
Old May 3, 2006 | 10:02 PM
KaoticFdR1's Avatar
Be a Hero...Punch a Koala
MAKE SURE YOU DON"T USE A 12 POINT SOCKET!!!!!!!!!!! you'll round it off in a heartbeat.....i used a impact socket 1/2" drive and a big breaker bar with a 3/8"' flat stock of aluminum about 6 feet long as a brace in the flywheel (between the dowels)
Old May 4, 2006 | 12:56 PM
dreadseb's Avatar
Alright I doubt that will be to tough for me to do, as long as I try turning the bolt the right way which in my opinion would be to the right, could somebody please verify this for me so I dont end up breaking it off or worse.
Old May 4, 2006 | 07:52 PM
Midwest 7's's Avatar
sellout
you must heat it up because it has the permenant loc-tite stuff on it, make sure you redo it when you reassemble.
Old May 4, 2006 | 09:14 PM
Carzy Driver's Avatar
Law Breaker
turn it counter-clockwise for it to come out
Old May 6, 2006 | 01:34 PM
ecarver2's Avatar
local Celebrity
I ended up using a 1/2" regular craftsman ratchet with like a 6' cheater bar This is after i broke a 1/2" breaker bar also craftsman) Go figure the ratchet actually did a bettr job.
Old May 6, 2006 | 07:58 PM
dreadseb's Avatar
Really how have you guys had such a slightly easier time with this, I had a 1/2 breakerbar with a 6' snipe and it ended up breaking the breaker bar, after supper or tommorow I'll be moving up to a 3/4 breaker bar and perhaps a longer snipe and we'll see what happens then, and thanks for all the suggestions so far.
Old May 6, 2006 | 08:21 PM
C. Ludwig's Avatar
www.lms-efi.com
The early cars are fairly easy. Starting with the 3rd gen the factory torque spec was upped to 180-200lb/ft and they used loctite on top of that. Heating the bolt is just about mandatory if you don't have a super dickle pissed impact. Some guys set a breaker bar against the frame rail and bump the starter motor to loosen the bolt. Your results may vary.
FD7KiD
15
Feb 26, 2021 10:12 PM
lduley
65
Feb 26, 2016 06:09 AM
FD7KiD
Aug 17, 2015 11:50 PM
rx7jocke
Aug 15, 2015 03:36 PM
