turbo oil/water feedline help
Old Apr 15, 2006 | 07:44 PM
ProjectD's Avatar
I'm on a Boat!
turbo oil/water feedline help***pix***
Ok guys here is my problem. I just received my garrett to4R turbo from rx7store.net and there is a problem with the turbo oil/water feed fittings.
I need to know exactly what size the fittings are from the turbo oil feed line and the ports on the turbo it goes to. They are both female connection. but i didn't receive the fitting(s) that go in between it.
They also gave me the banjo bolt and fitting for the water feed/return line. but they are too small for the openig on the turbo. I need to know what size the wholes are on the turbo. I am quessing about a 16mm because i took the banjo bolt to autozone and they said it was a 14mm x 1.25 or 1.5(something like that.)
If anyone could tell me where i could find the banjo bolts and fittings for the things i need it would help a lot.
Thanx in advance,
Cyan
Old Apr 15, 2006 | 08:02 PM
ProjectD's Avatar
I'm on a Boat!
[IMG][/IMG]
[IMG][/IMG]
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
FD7KiD
Aug 17, 2015 11:50 PM
