I smell gas
Old Apr 6, 2006 | 04:55 PM
Ramirez's Avatar
Newbie
I smell gas
When i drive me 1991 Rx7 i smell gas anyone got any suggestions to what may be the promblem ?
Old Apr 6, 2006 | 05:05 PM
Madrx7racer's Avatar
running rich...........check fuel lines, fuel filter, pulsation dampener and see if you have leaky injectors.............it could be a bunch of things. post details..............you won't get anywhere being vauge
Old Apr 6, 2006 | 05:07 PM
hondahater's Avatar
spending too much money..
search but since that button must be broked on your computer you should check your pd (pulsation dampener) on your fuel rail. They have a tendency to leak and cause engine fires so I would not run it until you find out exactly where it is comming from.
Ramirez's Avatar
Newbie
ok thnxs
Old Apr 6, 2006 | 05:08 PM
LAN's Avatar
LAN
Take a shower or clean your car inside...
Windows open? Gasoline or Exhaust? I know you said "Gas"....
Windows close - Smell any?
Old Apr 6, 2006 | 05:10 PM
Ramirez's Avatar
Newbie
no it defintely is coming from inside, near the stick alittle
Also, this Rx7 does not have turbo. I wanted to install a turbo but was wondering if i could do it without adding parts ( since im on a budget ) or do i have to buy a new engine.
Old Apr 6, 2006 | 05:16 PM
s4Lt's Avatar
I'm rotary for life!
I smelt gas in my car when I tried to mount my amp to the trunk, I drilled a little too far.
I fixed it by covering the hole with some gew.
Old Apr 6, 2006 | 05:22 PM
s4Lt's Avatar
Buying a new TII engine might cost you a little less.
I know I want to drop a TII engine, will cost about 2050$ installed and me able to drive it out.
Old Apr 6, 2006 | 05:23 PM
Ramirez's Avatar
Newbie
its just the engine ?
Old Apr 6, 2006 | 05:29 PM
exhaust leak?
Old Apr 6, 2006 | 08:05 PM
RylAssassin's Avatar
Ramirez huh i think were related
Old Apr 6, 2006 | 08:12 PM
search................
ls1swap
Jun 3, 2024 03:25 PM
userjh5174
Alternative Fuels
Jan 9, 2016 08:49 AM
Aramir
Oct 18, 2015 02:39 AM
musker
Oct 1, 2015 05:58 PM
