Bad Coil Spings?
Old Feb 4, 2002 | 10:58 PM
myron96's Avatar
Bad Coil Spings?
Querstion. If I press down on my front left fender, and there is a groaning noise coming from the area of the strut mount, however, i replaced the strut mount, could it be a bad coil spring? when I lift up on the fender after pressing down on it, the fender rises up a bit, and the groaning noise happens again.. Any ideas?
John
Old Feb 4, 2002 | 11:00 PM
amemiya's Avatar
struts
Old Feb 4, 2002 | 11:29 PM
Poindexter10thae's Avatar
AKA Poindexter
1. cut the wheel all the way in the direction of the suspected bad strut/spring.
2. try to do a power brake or just like a slow doughnut, if the sound emits, it is the strut.
The groaning sound is most likely a strut, the coil springs will make a popping sound. When you replace the strut, check the spring anyways to see if it is warped/bent/mishaped.
Old Feb 6, 2002 | 09:23 AM
myron96's Avatar
Hey, thanks guys. Im gonna check the strut... JOhn
Old Feb 6, 2002 | 12:10 PM
FPrep2ndGenRX7's Avatar
Might want to check the bushings on the lower control arm also. The factory oil cooler lines are known to start leaking when they get older and they are near the front bushings. The oil will eventually break down the rubber.
Old Feb 6, 2002 | 01:24 PM
SureShot's Avatar
Seduced by the DARK SIDE
My 91 suspension groans & clunks. It's due for new bushings. Your 85 may be over-due for bushings.
Old Feb 6, 2002 | 01:48 PM
Grimlock's Avatar
hmmmm
i didnt know our cars had spings????
Old Feb 11, 2002 | 07:59 AM
myron96's Avatar
Hey! I fixed the problem, turned out to be the stut mount, all I had to do was to rotate it about 90 degrees, and its perfect!!! No More noises!!!!
rgordon1979
40
Mar 15, 2022 12:04 PM
The1Sun
Sep 15, 2015 04:45 PM
windom
Sep 11, 2015 04:48 AM
SakeBomb Garage
SakeBomb Garage
Sep 4, 2015 05:20 PM
SakeBomb Garage
Vendor Classifieds
Sep 4, 2015 05:19 PM
