1 piece apex seals?
Old Feb 4, 2002 | 09:35 PM
1 piece apex seals?
Anyone know where i can find a set of 1 piece STEEL apex seals for my 12a bridgeport?. I know they make carbon ones but the 20,000mile lifespan doesnt really thrill me!. Do they even make them in steel?.ThAnKs!.
Old Feb 4, 2002 | 11:55 PM
smnc's Avatar
EliteHardcoreCannuckSquad
I think you mean iron seals. Steel would be kinda rough on the rotor housings.
Old Feb 5, 2002 | 12:20 AM
Iron or Steel what ever they came with!. Anyone!.
Old Feb 5, 2002 | 12:37 AM
Rotortuner's Avatar
Undercover
I am curious about this too. But I don't think they are avaliable because the iron might not expand right or something. Also they figure if your bridge, your going to run more than 9k so you want carbon anyways. but they are wrong there are still some of us out here who have great faith in the iron seals. I am useing iron in my p port.
CJG
Old Feb 5, 2002 | 06:49 PM
moremazda's Avatar
Gone Race'n
Mazdatrix sells them BUT You must have them machined to fit!!!!
Old Feb 6, 2002 | 01:04 AM
peejay's Avatar
Old [Sch|F]ool
Yeah I don't see the point either... 1 piece means you have to make the seals fit "short" so they don't bind when they expand, this means poorer low RPM compression just like a carbon seal, but since they're still heavy they are RPM limited just like a stock iron seal.
Hurleys are supposed to last longer (about 60k miles) but they're also supposed to do a real number on the rotor housings because of their poor friction properties. (rotor housings end up wearing scuffed instead of staying shiny) If you want revs then carbons are really your best bet, plus they're cheaper too!
Old Feb 6, 2002 | 03:01 AM
RotorMotorDriver's Avatar
Seven Is Coming
Wow...educational thread Thnaks!
~T.J.
Old Feb 6, 2002 | 10:11 PM
smnc's Avatar
Hurley Seals
Hey peejay, tell me about the Hurley seals... I was thinking about their Duplex seals for my rebuild next year, but nobody seems to know much about 'em...
Old Feb 6, 2002 | 10:21 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
doesnt atkins rotary sell them, I dont have a url, but they always on ebay with apex seals and motors
Old Feb 6, 2002 | 10:33 PM
peejay's Avatar
Old [Sch|F]ool
Hunt around in the general Q&A, single turbo, and performance mods sections... I'm still learning about them myself. I'm thinking that the lower lifespan sould be a good tradeoff for the ability to run more RPM than stock irons.
I've also heard that 1-piece seals are only needed if you bridge port so large that you need to relieve the rotor housings. Plenty of people using 2pc seals with a half-bridge (only the end plates are bridged and relieved) and the apex seals oriented so the corner piece rubs against the center plate. I've also heard )same source) that if you don't relieve the housing you can run a bridge with the corner piece, but that still strikes me as kinda iffy. (Then again I haven't done it... yet)
The Hurleys also seem to have a problem with large exhaust ports... as you make the exhaust port wider, there's less metal supporting the apex seal, because the break between the two is closer to the middle than the ends.
