No compression
Old Dec 25, 2005 | 02:09 PM
Cusco20B's Avatar
No compression
hey, i was doing a compression test today on a 88 gxl i jus bought and the trailing rotor had 0 compression. Is it possible to have 0 compression and if so do you guys know what might be causing it...? thanx in advance. Oh and i did the poor mans test also and i couldnt hear shiat. so yah.....
Old Dec 25, 2005 | 05:25 PM
kanuk93gt's Avatar
Engineering Student
it can have 0 compression and most likely bad apex seals
Old Dec 26, 2005 | 02:09 AM
KompressorLOgic's Avatar
I
if you get zero compression all around, and no poofs or noise out, of that rotor, then apex seal failure is allmost 100%, the motor is blown, sorry to give the bad news if you didnt see it coming...
Old Jul 2, 2006 | 03:35 PM
WesterBoyz's Avatar
Newbie
would you please tell me how to do that poor man's compressino test? I saw it on a site & it's not up there now. we're working on our 85 rx7 w/ 13b turbo. thanks!
Old Jul 2, 2006 | 03:43 PM
RotaryEvolution's Avatar
Sharp Claws
pump a few squirts of MMO in both leading plug holes and do the unflooding procedure to try and fire it up. it is possible the seals are just sticking so running the engine is the only possible method of freeing them up.
Old Jul 2, 2006 | 07:50 PM
HeffBoost's Avatar
Keep Right Except to Pass
^My line of thinking. How long has it sat?
You can take the exhaust mani off and examine the apex seals through the exhaust port.
turbodreamz22
28
Nov 10, 2023 11:08 AM
Andrew7dg
Aug 6, 2017 01:41 PM
93FD510
Oct 1, 2015 02:00 PM
