bolting 2 13b tts together
Old Dec 12, 2005 | 11:38 AM
girlzlover12's Avatar
I was wondering what modifications need to be made to bolt two 3rd gen motors together and make it run
The plan is to build a 4rotor motor and use two t-76 turbos (1 for every 2 rotors ) 2 large intercoolers and tune the motor for more horses
I want to build a rotory powered car that can match the veyron in horses and torque so instead of using 2 v8s I want to use two highly tuned rotorys.
I will be building my own frame and if I can also fiberglass the body myself.
This is way more advanced then anything I have done and any information regarding building a car from scratch will most likely be useful.
Old Dec 12, 2005 | 12:25 PM
13btnos's Avatar
Only people I've seen do it successfully http://members.tripod.com/~grannys/4rotor.html hope you have money.
Old Dec 12, 2005 | 12:48 PM
onefastrx7turbo's Avatar
Merovingeon
Veteran: Air Force
what you need is....about 30G's. welding skills, a custom e shaft and duct tape
Old Dec 12, 2005 | 10:36 PM
R.P.M.'s Avatar
Likes to swear....alot
Yes....duct tape will be key!!!
Please post pics of it when your done
Old Dec 13, 2005 | 08:11 PM
diabolical1's Avatar
wow ... not even a full week.
well ... i wish you luck.
Old Dec 28, 2005 | 03:26 AM
savana's Avatar
savanna
buy a proper quad e shaft from
http://www.kiwi-re.com/wwd_showroom_cat10_2.php
much easier than trying to couble to engines and trying to set endfloat on both individual engines when its coupled
Old Dec 29, 2005 | 01:38 AM
RX7_Fanatic's Avatar
R.I.P. DAVE
at sevenstock 8, there was a booth that had a 4 rotor rx7, if anyone knows who that was, you could probably look them up and see how they did theirs. was so long ago i dont remember the name at all, all i know is that they were in the back with all the other manufacturers, companies, and shops.
Old Dec 29, 2005 | 12:27 PM
13btnos's Avatar
http://www.autotechmotorsports.com/projects-4rotor.htm 4 rotor 12A wish they would have turned it on so we could have heard it.
Old Dec 29, 2005 | 01:02 PM
BoostedRex's Avatar
NorCal 7's Co-founder
Wow, that's a pretty cool shop. From what they said that "23A" 4 rotor they built mounts up in the same space that a traditional 20B would mount in.
cleann88
Jan 15, 2022 11:28 AM
Ian_D
Oct 14, 2015 12:31 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
Ian_D
Sep 6, 2015 10:38 PM
