lost 5th gear
Old Nov 26, 2005 | 03:19 AM
joeyz87's Avatar
lost 5th gear
Ok ever scince i had 93fd (no mods) she has made a little grinding sound when I shift into 5th gear. Now I can not shift into 5th at all. I'ts like the gear isnt even there. I still have 1st, 2nd, 3rd, 4th, and reverse. It doesn't make the grinding sound anymore when i try either. Has anyone else had this problem?
Old Nov 26, 2005 | 07:13 AM
dgeesaman's Avatar
That broken 5th synchro is now out of position and blocking the clutch sleeve from engaging the gear. Make sure to have a new 5/R clutch sleeve on hand as well as 5 synchro when you have it fixed.
Dave
Old Nov 26, 2005 | 09:17 AM
dubulup's Avatar
development
^damn I love reading your posts about tranny's...I learn so much. I guess until I tear one down, they will flabbergast me, haha.
Old Nov 26, 2005 | 08:17 PM
dgeesaman's Avatar
Haha, nobody knows if I'm full of **** though
Dave
Old Nov 27, 2005 | 08:19 AM
BigIslandSevens's Avatar
Hey Dave,.. Can you replace the parts you listed without having to tear the tranny completly apart? Do you just remove the rear housing? Or complete tear down. Thanks. I would like to take care of this over the winter.
Any odd speacial tools needed? That only Mazda makes
Damn! Got a link to his write up?
Old Nov 27, 2005 | 08:20 AM
dubulup's Avatar
development
well I've read your write up...and you've offer to rent the tools, etc...
DUBULUPAPPROVED
^been stamped off
Old Nov 27, 2005 | 09:19 AM
dgeesaman's Avatar
For 5th clutch sleeve and synchro, you only need a big socket (1-1/4"?) to remove the countershaft nut, and a set of extensions to make an extra-long 2-jaw puller. I also had to grind the ends of the puller a bit since they didn't quite fit under the edges of one of the bearings. For a complete rebuild you'll need some more bearing pullers, a press, and a super-deep socket or some other socket for the mainshaft locknut.
5th synchro is not a complete teardown - just need to remove the extension housing, rear bearing plate, and 5/r housing. I've heard it can be done on the car, but I've never tried it. I just stand the tranny clutch side down and work down.
My writeup is at www.davidgeesaman.com - but there are some other writeups linked in the FAQ that cover just 5th synchro more concisely.
Dave
Old Nov 27, 2005 | 06:57 PM
joeyz87's Avatar
So how much would a shop charge me? aprox. I dont have tools otherwise id do it myself.
Old Nov 27, 2005 | 07:26 PM
dgeesaman's Avatar
I dunno - $500? Call a rotary shop and tell them you need a 5th synchro job.
Dave
Old Nov 27, 2005 | 07:27 PM
Rotofire's Avatar
Yea, I'm working on it...
http://mahjik.homestead.com/files/ho...o/synchro.html
Read on!
Oh and Dave, I'm a newbie to FD's (but not FBs) And your write-ups are awesome....Nicely Done!
MILOS7
Oct 9, 2015 02:19 AM
Coochas
Oct 3, 2015 04:49 AM
musker
Oct 1, 2015 05:58 PM
