Mop
Old Oct 31, 2005 | 02:57 PM
dr. gonzo's Avatar
Mop
What Will Happen If The Omp Is Left Disconnected On An S4?
Old Oct 31, 2005 | 03:37 PM
nopistons's Avatar
[QUOTE=dr. gonzo]What Will Happen If The Omp Is Left Disconnected On An S4?[/QUOTE
^ You'll be changing the engine. If you have no MOP, you'll have to premix.
Old Oct 31, 2005 | 03:43 PM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
if you mean the rod that connects to the throttle linkage... it'll be just fine at idle, but won't get enough oil otherwise...
if you mean the ecu plug... nothing... s4's don't have an ECU plug, they're mechanical.
Old Oct 31, 2005 | 04:42 PM
HAILERS's Avatar
HAILERS
The engine will wear out a lot sooner. I'd guess after around thirty/fifty thousand miles .
Like he said in the thread above, the omp will still be metering oil if the rod is disconnected, but only for the amout for idle speed.
The first rotary engines did not have OMP, from what I gather (guessing). They wore out pretty darn quick from what I hear.
Old Nov 1, 2005 | 12:27 PM
dr. gonzo's Avatar
How About If You Leave The Omp Disconnected On An S4 Motor Using An S5 Ecu?
Old Nov 1, 2005 | 12:30 PM
SureShot's Avatar
Seduced by the DARK SIDE
The S5 ECU will throw a code & go into default (limp home) mode.
sunshine's Avatar
the S5 ECU will not function properly.
The lack of a MOP signal to the ECU will cause it to go into Limp mode.
-a
damn u sureshot...beat me to it! lol
jtm7878
22
Nov 25, 2003 10:52 AM
ajsuper7
Sep 23, 2003 09:08 PM
Black13B
45
Jul 16, 2003 09:18 AM
Bambam7
19
Jun 10, 2003 10:59 PM
telus.net
11
Jun 12, 2002 08:59 PM
