What's this tube doing on my engine?
Old Jan 23, 2002 | 04:53 PM
Snrub's Avatar
What exactly is the tube with the screw in it doing? What is it attached to? This doesn't exactly look OEM. ('87 TII)
Snrub's Avatar
Another view.
Old Jan 23, 2002 | 04:54 PM
Snrub's Avatar
For real this time.
Old Jan 23, 2002 | 04:58 PM
Snrub's Avatar
Next.
Old Jan 23, 2002 | 04:59 PM
Snrub's Avatar
Last one.
Old Jan 23, 2002 | 05:05 PM
GTUsGUY's Avatar
maybe if you take a pic more panoramic.
Old Jan 23, 2002 | 05:09 PM
jeff_oner's Avatar
i have one of those too but i haven't really thought twice about. but now im curious
Old Jan 23, 2002 | 05:35 PM
Snrub's Avatar
Perhaps if I explain where it is. The spot is the pasenger's side close to the firewall. You can actually see the firewall a bit in one of the shots. I suppose I could take another if you guys can't figure it out...
Old Jan 23, 2002 | 05:47 PM
j9fd3s's Avatar
Community Builder
is it for the cruise control?? i dunno i had mine like that too
mike
Old Jan 23, 2002 | 06:47 PM
86Rx7GXL's Avatar
Yeah thats on my 87 tII to, Have no clue what its for, the end closest to the passenger side had a plug on it on the other end witch is right on the other side of the lower intake had a short hose on it that looked like it would hook up to the gold color pipe out of the sub zero injection piece that bolts to the lower intake but it wasent hooked up. Theres three nipples on that sub zero injection piece one goes to the tank the other is a vac line that goes up to the upper intake and the other is the one im talkin about. I dont see any other places it could hook up to they dont even show that line in the haynes manual.
Old Jan 23, 2002 | 06:51 PM
Scott 89t2's Avatar
SOLD THE RX-7!
hmm that might be the line for the cold start blocked off??. there was a TSB about that to block it off, cause the system doesn't work.
Old Jan 23, 2002 | 07:35 PM
Snrub's Avatar
Any idea what the three lines that are touching it do?
Old Jan 23, 2002 | 09:13 PM
86Rx7GXL's Avatar
All right think I got it figured out, In the pic I attached you can see that A and B look like they would connect just like all the other lines going out to the ACV. A is the line from a solenoid that goes to the switching adulator on the exhaust manifold. so the line C that everyone's is plugged or just there was a different rout that Vac hose could be ran to go to the switching adulator. Witch makes more sense cause the line that came with my j-spec looked like it went up by the ACV instead of A.
Old Jan 23, 2002 | 09:18 PM
86Rx7GXL's Avatar
pic
Old Jan 23, 2002 | 09:25 PM
86Rx7GXL's Avatar
alright some reason i cant post this pic, and i cant delete post i put on there if you need it email me
RotarHead13BT@aol.com
Old Jan 23, 2002 | 09:47 PM
86Rx7GXL's Avatar
Tryin it again
Old Jan 23, 2002 | 10:51 PM
Felix Wankel's Avatar
Super Newbie
Mine was plugged off as well. There was like 4 lines, and only 3 were used.
Old Jan 23, 2002 | 11:38 PM
Snrub's Avatar
Thanks guys. That sounds good and makes me feel better. I thought something was totally screwed up on my engine. It's very weird that they'd have that thing there only to plug it. Costs mazda extra money for something that does nothing!
FD7KiD
15
Feb 26, 2021 10:12 PM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
FD7KiD
Aug 17, 2015 11:50 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
