mild ported t2 dyno 236 hp 187 tq @ 9psi.
Old Sep 29, 2005 | 12:57 AM
-=Lil Red=-'s Avatar
R.I.P. Guitarjunkie28
well i finnaly got Dave (Guitarjunkie) to dyno tune my car today.
he got it to run 11 AFR's across the RPM band.
mods are:
freshly rebuilt jspec 13bt.
very mild street port.
full intake, and straight exhaust.
720cc secondaries controlled by safc2.
ported wastegate on stock rebuilt turbo.
running 9psi.
stock Top Mount Intercooler.
236 hp 187 tq @ a conservative 9psi.
Attached Thumbnails mild ported t2 dyno 236 hp 187 tq @ 9psi.-fris_graph-1.jpg
Old Sep 29, 2005 | 01:01 AM
GUITARJUNKIE28's Avatar
multipersonality disorder
turbo spooled too late, otherwise the torque would have looked nicer.
the first pull actually did 240 whp, but afr's weren't safe, so i toned it down from there.
Old Sep 29, 2005 | 01:04 AM
Makenzie71's Avatar
...94% correct.
wow...nice.
Old Sep 29, 2005 | 01:07 AM
arghx's Avatar
rotorhead
yeah that torque is really low... my buddy had a similar setup (except stock ports) and he put down 250rwhp/280rwtq at I think 14psi
Old Sep 29, 2005 | 01:17 AM
yea its my turbo wastegate that i ported to 33mm and its doesnt seal perfectly. it makes it lag alittle cuz of the leak.
Old Sep 29, 2005 | 01:28 AM
it wasn't hitting full boost until ~4k-4200 rpm.
btw, i think i have an s4 snail at my buddies house. i can port that wastegate and slap that on...we can see what that does to the spoolup.
in any case, it's pretty good numbers for the boost level.
Old Sep 29, 2005 | 10:46 AM
lets try it, or do u think an s5 hot side will be better cuz i can get one from my friend.
Old Sep 29, 2005 | 11:11 AM
ultradef's Avatar
Ready to Rock
Nice numbers! The port couldn't be too small considering the hp numbers on only 9 psi. Get that wastegate problem fixed and your torque curve will be much nicer...my stock S5 turbo spools almost instantly!
Old Sep 29, 2005 | 12:05 PM
Makenzie71's Avatar
...94% correct.
what kind of number do large port jobs generally see? Or, further, what kind of power are 14.0/sec TII's putting down? The car ran 14 even repeatedly on stock boost.
Old Sep 29, 2005 | 01:58 PM
gerbraldy's Avatar
wtf's a piston
It probably had a large streetport.
Old Sep 29, 2005 | 04:01 PM
the streetport is very very small
Old Sep 29, 2005 | 04:49 PM
it's not about size, it's about flow! but thanks
Old Sep 29, 2005 | 04:50 PM
fris, s5 hotside would be fine, but we'd have to find a manifold for it.
Old Sep 29, 2005 | 04:57 PM
MrDirt's Avatar
Your friend made a ton of torque because his turbo is maxed out at low in the RPM range. If he was running a suitable turbo for his setup, you would see the HP numbers far exceed the torque.
Old Sep 29, 2005 | 05:02 PM
Andrew.'s Avatar
The end of an era
How bout you slap that snail at your buddy's house on my fc dave? Congrats on your numbers fris!
-Andrew
Old Sep 29, 2005 | 07:48 PM
^ exactly.. 240 horse, 280 tq isn't uncommon.. boost curve looks like a big rainbow, and torque usually looks just like an upside down "V" though
this one HELD 9psi with late spoolup all the way to redline.
Old Sep 29, 2005 | 07:55 PM
Whizbang's Avatar
Respecognize!
wow. this makes me want to get my car tuned sooner...
Old Sep 29, 2005 | 11:58 PM
FC3S_nataku's Avatar
mattg prob nt coming back
well now i know what kind of numbers im going to put down in like 6 more months
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Clacor
Sep 11, 2015 08:36 PM
SCinfidel
Sep 8, 2015 05:36 PM
