hose replacement
Old Jan 13, 2002 | 04:30 AM
trigeek37's Avatar
hose replacement
more questions!
I keep reading that the FD needs to have it's hoses replaced, and I was wondering what hoses should be relpaced, when, and with what. My FD has 40k miles, and has very regular maintaince. It is in storage now, and soon I will be starting upgrades sometime this later winter/early spring. Also, where is the best place to get hoses, the rx7store? and I am assuming that there are a varity of hoses that you can use to replace the stock ones, what are the best? Price is of course an figure here, but I am more intereted in gettnig hoses in the car that will ensure longevity and continued preformance.
thanks again
Old Jan 13, 2002 | 06:33 AM
maxcooper's Avatar
WWFSMD
Unless you have boost problems or have the motor apart anyway, I think it makes sense to leave the stock hoses in place. If/when you decide to change them, most people use silicone (~25' of 4mm-ish, ~10' of 6mm). I get my silicone hose from Baker Precision. Thick-walled Viton hose from McMaster-Carr or other suppliers is probably the best solution, but it is much more expensive.
-Max
Old Jan 13, 2002 | 08:27 PM
If I were you listen to the guy on top, dont change them unless your rebuilding your motor or having boost problems. Its the biggest bitch in the world to do!
Old Jan 13, 2002 | 08:44 PM
m_snoby's Avatar
Well I've taken from this community long enough... It's time to give back.
Please visit Rob's website
http://www.rx7turboturbo.com/robrobinette/hoses.htm
This will tell you everything you need to know, plus it has some outstanding other information.
I hope this helps.
Old Jan 13, 2002 | 09:00 PM
Cetchup's Avatar
The Cursed FD
Hostechniques
What about the Hosetechniques hose job? Is that any good? it's only $118... Anyone have this done on their FD?
Old Jan 13, 2002 | 09:07 PM
1FAST7's Avatar
Do you have to take the engine out? or is there a way to install the silicone vaccum hoses without taking the engine out?
1FAST7
Old Jan 13, 2002 | 09:13 PM
m_snoby's Avatar
Good Lord man... NO you don't have to pull the engine to do that!!!!!!
You have to take the Plenum off the car, (The curved metal thing that the air goes into ... the upper intake manifold). Just follow the directions on Rob's site and you will be fine.
Old Jan 14, 2002 | 09:36 AM
RonKMiller's Avatar
Blow up or win
1FAST7
You really SHOULD take your car to someone and have them do it for you. It is MUCH more difficult than it appears and requires testing of solenoids and check valves as well as replacing hose.
Although it would be a lot easier with the engine out!
Old Jan 14, 2002 | 10:34 AM
GsrSol's Avatar
Z06 powered FD
I used mostly 3.5mm hose from hose techniques, and a little bit a 4mm and 6mm. If you have no idea what you're doing, I highly suggest you don't do it.
Old Jan 14, 2002 | 10:42 AM
tnt's Avatar
tnt
I reccommend bypassing all the solenoids and switching to twin, it simplifies everything and i think they run better that way, i did it to mine before i went single and have done it to a few customers cars without any complaint....
Shaun
rgordon1979
40
Mar 15, 2022 12:04 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
Apoc3D
Sep 5, 2015 10:24 AM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
