First drive with new turbo.
Old Jul 26, 2005 | 08:04 PM
IronMdnX's Avatar
Glutton for Punishment
I finnaly got it all in and took it for a quick spin. It's a little more laggy than i thought. It starts spooling at 3800-4000 and full boost by 4500-4800. Maybe I'm just use to the stock twins having full boost by 3000-3200. I've only have set at 10psi for now until i get it tuned in a bit more. She sounds awesome, it screams under boost. The new 4" exhaust is plenty loud even with a resonator, maybe I'll need to add in another if ther is room.
More info and pics to come.
Old Jul 26, 2005 | 09:04 PM
CCarlisi's Avatar
Rebreaking things
Thanks for the info. Can't wait to hear it!
Old Jul 27, 2005 | 12:35 AM
t-von's Avatar
Rotor Head Extreme
Are you still running with stock ports?
Old Jul 27, 2005 | 07:44 PM
IronMdnX's Avatar
Intake ports are Judge Ito templates, I could have gone bigger on the exhaust ones, but i didn't want to go too far.
The turbo is a innovative GT80R , 1.32 A/R R-Trim hot side, and dual Ball Bearing. I thought it would spool sooner buy maybe the R-trim wheel i bet is causing some additional lag.
Now to deal with the excessive heat off the turbo and downpipe. My passenger side wheel liner is starting to warp. What's everones experience with ceramic coatings or a thermal blanket for the turbo pluss wrapping the downpipe?
Old Jul 27, 2005 | 07:51 PM
IronMdnX's Avatar
Pics
Old Jul 27, 2005 | 09:06 PM
RX-Heven's Avatar
I'll blow it up real good
I ceramic coated my dp, exhaust manifold, and turbine housing. The underhood temps have been drastically reduced and now you vcan actually get your hands near the turbo/downpipe after shutdown whereas before I wouldn't even think about it.
It works, but I'm still going to put up some additional shielding between the dp and intake manifold.
Old Jul 27, 2005 | 10:16 PM
CCarlisi's Avatar
Rebreaking things
How much room do you have between your air filter and the turbo inlet?
Old Jul 27, 2005 | 10:40 PM
94RHDFD's Avatar
Formally 20b 3rd gen
HPC has a 2200 degree heat coating, I'm having them do my DP, exhaust manifold, A/R housing, and wastegate
Old Jul 27, 2005 | 11:37 PM
GtoRx7's Avatar
Collections Hold
is it just me or is the oulet hose a little kinked? Nice setup.
Old Jul 29, 2005 | 05:03 PM
ReZ311's Avatar
KM48 Burnout
Themal heat wrap is very effective. If you want to jet coat it, go for it. $40 for heat wrap.
Old Jul 30, 2005 | 02:35 AM
Jeff20B's Avatar
Lapping = Fapping
Is that a Greddy intake elbow? I think I'll need one since my stocker is preventing my hood from closing. How's the fit to the stock TB? Do I have to drill and tap a hole for the air temp thermistor? Thanks.
whizzybang
Naturally Aspirated Performance Forum
21
Feb 10, 2017 12:08 PM
