Wolf 3D Discuss the Wolf 3D Engine Management System
Wolf 3D POS Wolf and CAS rpm incorrect
Old Jul 25, 2005 | 10:46 PM
VaGambler's Avatar
I am working on a S5 T2 with stock engine and have a stock and moddified CAS's. My problem is getting a stable RPM reading on the Wolf3DV4. The RPM indicated during cranking is normally at around 250 with jumps to 1200 or maxed into the redline. I have not been able to get the RPM to steady out during cranking. Any help before I ****-can this Wolf for a Microtech. Engine is all stock at this piont and I am just trying to start the car right now. I have moved the trigger wires so that it goes from the CAS strait to the Wolf (had a spare harness) to avoid interferance, but nothing changed.
File Type: wmf
Old Jul 25, 2005 | 10:51 PM
nyt's Avatar
nyt
read your PM that i replied to you
Old Jul 25, 2005 | 10:52 PM
nyt's Avatar
nyt
p.s. your map wont load for me
Old Jul 26, 2005 | 02:34 AM
nyt's Avatar
nyt
the file you wanted
Old Jul 26, 2005 | 06:34 PM
VaGambler's Avatar
ok lets try this again, let me know if this works
thanks in advance
File Type: wmf
Old Jul 26, 2005 | 06:43 PM
nyt's Avatar
nyt
thanks in advance
nope not working
to save a map the best way is
file -> transfer
from connected ecu to pc file
Old Jul 29, 2005 | 12:58 PM
VaGambler's Avatar
ok, lets try this again
let me know if you get this one
Thanks in advance
File Type: wmf
Old Jul 29, 2005 | 03:24 PM
nyt's Avatar
nyt
Thanks in advance
nope. comes up as a blank map.
maybe you got a bad unit? somethin isnt working right.. and i opened this one on a different computer also.
Old Jul 29, 2005 | 06:31 PM
eViLRotor's Avatar
Brother of the Rotary
Just FYI, I can open the first two just fine...his last map is all zeroes.
Old Jul 30, 2005 | 01:35 AM
nyt's Avatar
nyt
theyre all 0's for me =[
Old Jul 30, 2005 | 05:37 AM
Michael Smith's Avatar
Thumbs down
Looks just like my bank account RED and all zeros!!!! You need to go online and load the data from the ECU then File transfer FROM Screen TO PC File ........add the name and then you should be off. My guess is that you already have a file with all Zero's of that name and you are not overwriting it.
Michael Smith
LongDuck
Oct 7, 2015 08:12 PM
eplusz
15
Oct 7, 2015 04:04 PM
James Knox
Oct 5, 2015 07:56 AM
musker
Oct 1, 2015 05:58 PM
