Failed emissions here's my numbers help.
Old Jul 21, 2005 | 01:50 PM
87WhiteComet's Avatar
Took my 87 TurboII for emissions today and failed. I bought the car used so I have no clue how long the car has been in emissions non compliance since it came from VW. Here's my numbers passed the Cat inspection and passed Evap test. Here are the ASM numbers...
HC 271.9 174.0
CO 0.64 1.12
NO 760.9 1258.0
CO2 13.87
The numbers on the right are Ohio's limit and the numbers on left are mine... As you can see I only failed the HC. Any help I'd appreaciate it otherwise I may consider getting collectors tags.
Old Jul 21, 2005 | 02:07 PM
Tournapart's Avatar
RIP Icemark
High Hydrocarbon levels are usually due to bad cats so just replace them and you chould be good
Old Jul 21, 2005 | 02:17 PM
Agent_D's Avatar
rawr
theres a guy selling a bonez high flow cat in the f/s section
Old Jul 21, 2005 | 03:10 PM
My stock exhaust right at the Y pipes both pipes have small crimps in them from the previous owner runnign somethign over. Could this restriction cause higher readings?
Old Jul 21, 2005 | 03:13 PM
RX7Dragon's Avatar
Recovering Rotaryist
Unless it damaged the cats, then no.
Old Jul 21, 2005 | 03:52 PM
I just purchased a hi flow bonez cat replacement will this cause fuel cut to kick in on a stock car?
Old Jul 22, 2005 | 02:32 AM
TurboVert7's Avatar
HC 271.9 174.0
CO 0.64 1.12
NO 760.9 1258.0
CO2 13.87
whats the O2 reading ? if its close to 0% your cats are fine if its high(ie. 1%) its not doing its job your co2 should be closer to 15% if its running good check your timing plugs and you should be good
Old Jul 22, 2005 | 07:51 AM
RETed's Avatar
The numbers are very close to passing.
Unless the HC numbers are like 1000+, then I would suspect the cat is dead.
Has the car gotten a tune up recently?
Replace spark plugs...
Replace spark plug wires...
Change engine oil...
Change air filter...
All of that actually helps.
Also, run the car HARD and get it hot just prior to taking the car in for testing.
Getting everything hot allows the cat(s) to work more efficiently.
Since it's also an '87 model, jack the "R" / "L" screw all the way to "L" as possible while still being able to idle.
This will lean out the idle air / fuel mixture to help.
Adjust the TPS to within spec.
Check ignition timing to factory spec.
Once all of this is done, I'd be pretty confident that car will pass.
-Ted
Old Jul 22, 2005 | 05:19 PM
I just had ordered my new plugs and wires so I'll have those in but I also have a brand new K&N cone filter and I also will be changing the oil this coming Thursday.
Thanks for all the pointers.
Old Jul 22, 2005 | 07:00 PM
unek87's Avatar
NA-BOOSTIN
you know i had the same problem were starting emissions down here in austin,tx and i was trainning on the machine so i hooked my car up well lets just say you already know so i start to lean it out to see if the numbers would change well they got worse so i start to richin it sure enough it passed course this was on a n/a so that may not help
Old Jul 22, 2005 | 07:07 PM
BLUE TII's Avatar
Rotary Motoring
High hydrocarbons...
Before you go the effort and cost of replacing the cats make sure the airpump and the Air Control Valve circuit is working correctly!
My friend had the same problem and this was the solution.
NEWGENRX7
Jun 26, 2019 12:20 AM
JP's 93 fd
Sep 16, 2015 01:12 PM
doritoloco
Sep 14, 2015 11:36 AM
SCinfidel
Sep 8, 2015 05:36 PM
