DaVinci Motorworks / Garrett AF61R turbocharger
Old May 22, 2005 | 10:08 PM
UnderConstruction7's Avatar
Cadillac_Slider
Yeah so, I was looking around RXTuner.com and I came by this article that mentioned a turbo made for the turbo rotary enthusiest. I personally was impressed with the numbers ( 393rwhp - 13psi @ 3700rpms on an unported 13b-rew ). I was wondering has anybody else used this turbo or seen it for that matter. I've searched all over this site to find it & it seems that it's unexplored territory. I was thinking about throwing in on a S4 13BT with a stage: 1 street port and some other internal mods. If anyone can supply some thoughts or info on this, i'd be appreciative.
Old May 23, 2005 | 12:30 PM
meddle's Avatar
Call them 618-222-1201. There website isn't finished.
Old May 23, 2005 | 12:42 PM
Bukwild's Avatar
60-1 on a second gen for anything under 375rwhp will be the best out their.
Old May 23, 2005 | 12:55 PM
dubulup's Avatar
development
WTF??
is that a typo or are you talking about spool time?
Old May 23, 2005 | 01:43 PM
Cadillac_Slider
I'm talking about full boost(13psi) from 3700rpms to redline. Yes, that would be spool time
Old May 23, 2005 | 02:12 PM
Bukwild's Avatar
if you are only running 13lbs than get a 60-1.
Old May 23, 2005 | 02:26 PM
meddle's Avatar
AF61R compares pretty favorably to the 60-1. It a great alternative to that turbo, and Ron offers top notch customer support. Probably save hima couple bucks too.
Old May 23, 2005 | 03:30 PM
BOOSTD 7's Avatar
Persona non grata
I'd much rather have the AF61R to a 60-1. The 61R kicked *** at 13psi, and would kick even more at 18-20 psi. The 60-1 just doesn't have what it takes to match up.
The good thing about the 60-1 is that you can find setups on Ebay for dirt cheap. However just over $2000 for the 61R is pretty damn cheap too.
Old May 23, 2005 | 08:33 PM
ghostrx7's Avatar
Well there seems to be a large discrepency with what shops claim their kits make and what they actually DO make...not naming any shop in particular but its more then one. 393whp@13psi seems a bit optimistic, maybe the dyno is set for 10,000 ft altitude correction;p
Old May 23, 2005 | 09:10 PM
meddle's Avatar
That 393 at 13psi was done on A-Specs dyno.
Old May 23, 2005 | 09:28 PM
BOOSTD 7's Avatar
Persona non grata
A-Spec did the dyno, AND the tuning ... I trust that number was real.
Old May 24, 2005 | 04:01 AM
Cadillac_Slider
Boostd 7, You were just the man I wanted to see in this thread simply because you've seen this turbo in action.
Old May 24, 2005 | 05:02 AM
Node's Avatar
anyone have a flowchart for this turbo
what a/r was the guys in rxtuner?
Old May 24, 2005 | 07:34 AM
RETed's Avatar
WTF is an AF61?
Sounds like an IHI?
It sounds suspiciously like the A'PEXi stuff...AX53, AX75, etc.?
-Ted
Old May 24, 2005 | 10:09 AM
LUPE's Avatar
It's not Apexi, IHI or anything else. It's a Garrett unit.
Old May 24, 2005 | 01:00 PM
MWM's Avatar
MWM
AF61R, is this some proprietary designation for a standard Garrett?
Old May 24, 2005 | 01:04 PM
Zero R's Avatar
Just in time to die
I do not remember this car at all. Do you have a sheet???
Old May 24, 2005 | 01:31 PM
Cadillac_Slider
I believe the car is in the RXtuner.com site under Articles "Going Single" That could help explain alot of questions. Hell, this would be where this topic originated
Old May 24, 2005 | 01:56 PM
LUPE's Avatar
It was red, had the new veilside kit on it...
The name AF61R was given to it by Davinci.
Old Jul 21, 2005 | 09:07 PM
jahnke's Avatar
http://www.rxtuner.com/farticles/GoingSingle.pdf
Here is the link to the article. I was interested in the kit as well.
Old Jul 21, 2005 | 09:17 PM
jahnke's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...tem=4563009351
The car is now listed on ebay too....with a new motor since the article was written.
Old Jul 21, 2005 | 09:20 PM
books's Avatar
here's a car with that turbo http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Old Jul 22, 2005 | 12:34 AM
cewrx7r1's Avatar
Eye In The Sky
393 RWHP at 13PSI boost on stock ports?
Not with normal street gas, or without water/alky injection. Pure BS!
Old Jul 22, 2005 | 07:21 AM
dubulup's Avatar
development
wtf is the awful looking thing coming off the turbo?
Old Jul 22, 2005 | 07:25 AM
Zero R's Avatar
Just in time to die
Cobra compressor outlet induction kit?
