Street Porting for a 60-1
Old Dec 20, 2001 | 01:10 PM
Jedon's Avatar
Slave2TheFD
My engine builder said the exhaust ports on the 13bREW are already big enough and that he just street ports the intakes. When I was discussing this with him though it was for stock twins, now I'll have a T04E 60-1 .7 comp, 1.15 A/R divided P-Trim and going for ~450RWHP. I'm getting ribbed water passages to help cooling as he said he does it to all his race engines. So anyway, do my exhaust ports need to be ported now that my turbo is so much larger? Thanx!
Old Dec 20, 2001 | 02:00 PM
David Hu$tlerhoff's Avatar
i'm not an engine builder but for me it seems logical that you need a bigger exhaust port. you got a bigger turbo, wich means it floows more air-gas mixture in the chamber. so there is more exhaust and this neds a bigger exhaust. my oppinion
Old Dec 20, 2001 | 05:29 PM
IGY's Avatar
IGY
If you don't port the exhaust side you will regret it. My last motor all I did was an exhaust port and one of my friends had only a side port and I would beat him running 3lbs less boost. He now has an exhaust port also and he beats me running the same boost.
Old Dec 21, 2001 | 08:27 PM
Judge Ito's Avatar
Lightbulb Remember
Remember the whole Idea of Porting your exhaust is to, Open earlier and close later. Even though the 13B REW exhaust ports are fairly large. U still need to Port.
Old Dec 23, 2001 | 12:45 PM
Jedon's Avatar
Slave2TheFD
Thank you Ito! My mechanic is Larry Scott, who usually makes NA bridgeports for rally racing, what should I ask him to do to my ports?
Thanx!
-Jedon
Old Dec 24, 2001 | 09:47 PM
Judge Ito's Avatar
let me see..
Jedon ask your engine builder to give the rotor housings a port similar to his regular N/A street port engine. the same rules that apply for porting your N/A/ engine, applies to your turbo engine as far as porting...
Old Dec 25, 2001 | 01:42 AM
Jedon's Avatar
Slave2TheFD
I don't think I need a bridge port like his race engines
So is there any difference in the way you port a turbo vs NA motor?
Thanx!
-Jedon
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Ian_D
Oct 14, 2015 12:31 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
