When soaking in ATF...
Old Nov 25, 2001 | 04:05 PM
When doing the ATF thing. After adding all the ATF I use (approximately 1/4 qt. per rotor) should I bump the starter every hour.... two hours.... three hours? What are the intervals for bumping if any?
Old Nov 26, 2001 | 04:25 PM
JerryLH3's Avatar
Rabbit hole specialist
It doesn't hurt to turn the engine over every few hours or so while the engine is soaking in ATF. You can either do it by hand or bump the starter or whatever method can be used to turn it over.
nycgps
30
Sep 29, 2015 12:02 AM
FC_DREAMS
20
Sep 22, 2015 09:43 PM
dradon03
Sep 18, 2015 05:57 AM
Monsterbox
Sep 11, 2015 03:29 PM
befarrer
Aug 14, 2015 04:18 PM
