1993 Oem Speaker Size
Old Sep 7, 2004 | 03:05 PM
cirQuis's Avatar
what is the OEM Speaker Size for the 1993 model?
Old Sep 7, 2004 | 03:11 PM
maxcooper's Avatar
WWFSMD
BOSE or non-BOSE?
EDIT: And which speakers? Door? Dash? Rear sides? Or Bose tube?
-Max
SpeedKing's Avatar
Power Trippin'
Non-BOSE? 5.25" front, 5x7 Rear, however, you can go 6.25" (shallow mount) up front, and 6x8 rear.
Old Sep 7, 2004 | 03:13 PM
maxcooper's Avatar
WWFSMD
My non-Bose front speakers were normal (but shallow) 6.5". The FWM says the size is 6.3". I suspect the 5.25" rumor is from people installing deep aftermarket stuff.
-Max
Old Sep 7, 2004 | 04:12 PM
SpeedKing's Avatar
Power Trippin'
Woops, 6.25" was a typo! 6.5" it is.
Old Sep 7, 2004 | 06:31 PM
pianoprodigy's Avatar
Missin' my FD
Allow me to re-emphasize...SHALLOW! I have Infinity Kapp Perfect Components (5.25) that I made a custom pod for. It was a big pain to get the depth just right. I would definitely look for something less than 2.5, and it was still a pretty big pain.
Old Sep 7, 2004 | 11:10 PM
SpeedKing's Avatar
Power Trippin'
What the part number on those wood brackets?
BTW pp, why didn't you just go 6.5"?
Old Sep 7, 2004 | 11:28 PM
Missin' my FD
Answer to Question 1: Part #waytoomanyhoursforspeakers
Answer to Question 2: I ask myself that daily to be honest...The Kappa Perfects are very clean and loud, but the midbass department is lacking a bit especially considering I am only running the components and the Basslink. Will I ever change them? Probably not considering how much work it involved.
Alan
Old Sep 8, 2004 | 01:32 PM
potatochobit's Avatar
yes the front speakers can not have a deep driver. so the back magnet must be small. this is why 5-5.25 is mostly recommended as almost all 6+ have large drivers.
Old Sep 11, 2004 | 11:21 PM
cirQuis's Avatar
how do you remove the center speaker? my ride is just a base 93 model(non bose)
Old Sep 12, 2004 | 04:40 AM
SpeedKing's Avatar
Power Trippin'
Pry the cover off. Unscrew the speaker. Easy enough?
Old Sep 12, 2004 | 12:28 PM
cirQuis's Avatar
some other rides(nissan or toyota) will require to remove the dash...which is why i asked the question...
Old Sep 13, 2004 | 04:16 AM
SpeedKing's Avatar
Power Trippin'
There's a cover in the middle of the dash. It's intuitive that you remove it to access the speaker, no???
Old Sep 13, 2004 | 07:49 AM
MR_Rick's Avatar
Planning my come back
I have 6 1/2s which are actually 6 3/4 up front. I just made a speacer ring out of 1/4" MDF and it fit nice. Gives me just enough clearence for the window. on the back I got regular 6 x 8
This are my front
http://www.mmxpress.com/Pioneer/tsd170r.htm
Old Sep 16, 2004 | 08:17 AM
Herblenny's Avatar
DGRR 2017 4/26-4/30, 2017
So, I'm I going to have problems fitting my Boston Pro 6.5's in the front?? I currently have Boston Pro 4's but they are way too small.. Sounds horrible..
Old Sep 17, 2004 | 01:01 AM
SpeedKing's Avatar
Power Trippin'
If the woofer exceeds a mounting depth of 2.5", then yes.
Old Sep 17, 2004 | 09:18 AM
David88vert's Avatar
r71's daddy
I can get them in there. It's a little drive to Atlanta, but if you really want to get them in there and have problems, PM me.
Old Sep 17, 2004 | 07:28 PM
Bob_760's Avatar
How do I made boost?
lol that looks EXACTLY like what i did
(i used the stock plastic pieces but have those same speakers and made an adapter out of wood which i sunk the speaker into like that)
where did you put your crossovers?
I stuck mine to the inside of the door skin with mirror adhesive squares
Old Sep 17, 2004 | 11:55 PM
Missin' my FD
Hmmm...let me think...crossovers...double stick tape...door skin...Yep! Pretty much
Old May 8, 2014 | 09:26 PM
kjrx7's Avatar
I was looking to install a 6.5 as well. I just ordered these PVC Speaker Adapters - CNC Machined - In Stock or Custom Made .has anyone used them? pianoprodigy...Do you know how much you had to build the speaker out?
Old Jun 3, 2014 | 08:36 PM
hairball's Avatar
I've used them to replace stock Bose they fit well mounted my x-overs on them too but with my 6.5 focals the glass hits the magnet on the way down I just don't roll my window down
Old Jun 13, 2014 | 10:08 PM
SUKS2BU's Avatar
Just build kickpanels and you will have no magnet depth or window issues. And way better sound!
Old Jun 13, 2014 | 10:59 PM
SUKS2BU's Avatar
If you want really good midbass upfront put some 5.25' midbass only in the doors playing from @100hz-600hz with a 24db slope passive crossover and put a good set of coaxials or components in some custom kickpanels. I used this set up in my S5 FC I competed with. This setup will make the kick drum range feel like it's coming from the front like at a real concert. Your sub should just provide some rear fill unless you want all your bass coming from the rear I don't.
Old Oct 6, 2014 | 06:36 PM
nemix's Avatar
So the bose system, what sizes should I be looking for?
Old Nov 4, 2014 | 05:58 AM
calio64's Avatar
Does anyone know?
I just got a fd touring and was thinking the same thing.... I don't have the nose system in the car anymore but I should of because of the touring model. Would like to buy speakers this week... Someone please help us out. Thanx
FD7KiD
15
Feb 26, 2021 10:12 PM
tridav3
Interior / Exterior / Audio
Aug 18, 2015 11:42 PM
FD7KiD
Aug 17, 2015 11:50 PM
