Sponsored by: CARiD
steering question
Old Jul 14, 2004 | 12:25 AM
Lothema's Avatar
steering question
91 manual na
is it a power assisted steering or just plain power steering?
Old Jul 14, 2004 | 03:10 AM
RETed's Avatar
Why don't you look under the hood?
-Ted
Old Jul 14, 2004 | 07:22 AM
Lothema's Avatar
i did several times, not exactly sure how to tell
Old Jul 14, 2004 | 08:33 AM
Project84's Avatar
Open up! Search Warrant!
Look for a power steering pump. It will be on the driver side of the engine bay. It will have a cap on it labeled "Power Steering Fluid". If you have A/C, there will be an A/C compressor over there too. Don't get the two confused, the A/C compressor doesn't have a fluid fill tube like the power steering pump.
Old Jul 15, 2004 | 02:30 AM
Lothema's Avatar
mainly im wanting to know if i remove the power steering will it be impossible to steer or will it be about the same as an 87 that didnt have the power steering
Old Jul 15, 2004 | 09:01 AM
Project84's Avatar
If you have power steering and remove it, it may be slightly stiffer than a car with a manual steering rack. Peoples opinion on that varies based on the size and strength of the arms. If you remove the PS pump, make sure you siphon some of the fluid out of the power steering rack before you cap the holes where the lines from the pump attach. If its full of fluid it will build up too much pressure. But you gotta have some fluid so it will lubricate the steering gear. I removed my power steering and the only difference I feel is when I try to turn the wheel when the car is sitting still. When the car is moving, even very slow, its not bad turning the wheel and its amazing how much more you feel the control you have over the front wheels. Its not as wishy-washy as with power steering.
Old Jul 15, 2004 | 02:12 PM
RETed's Avatar
In general, it will not be the same as a manual steering FC.
The manual steering rack ratio is 20:1.
The power steering rack ratio is 15:1.
With a reduction of 25%, I'm sure it'll be significantly harder to turn.
-Ted
Old Jul 15, 2004 | 04:37 PM
Lothema's Avatar
thanks for the info
Old Jul 15, 2004 | 08:05 PM
peejay's Avatar
Old [Sch|F]ool
Re: steering question
Originally posted by Lothema
91 manual na
HUH?????
"Power assisted steering" and "power steering" are two different names for the exact same thing.
matty
Jan 18, 2020 10:39 AM
c0rpse
Aug 25, 2015 11:50 PM
