T-stat ?
Old Jul 13, 2004 | 07:56 PM
crackedoutducky's Avatar
T-stat ?
if i take out my t-stat for the summer, will i have to put a new gasket back into the same place that one was at ? (just a quick question )
- Rob
Old Jul 13, 2004 | 08:18 PM
cdrad51's Avatar
Lorem ipsum dolor sit ame
don't take it out.
Old Jul 13, 2004 | 09:42 PM
Hades12's Avatar
Burning Oil-Grinding 3rd
Read a bit, there have been 10 threads in the last month.
dont take it out, there is a block plate at the bottom of it that changes the water from cerculating in the engine to going to the rad. RB says to block the hole by taping it with a 1/2 tap and putting a pipe plug in it if you want to run with out one. Wacky says to cut off the top part so only the block plate will function and water will always go to the Rad and when cold throught the engine some. Atkins sells a 160 T-stat if you just want to bring the temps down.
Old Jul 13, 2004 | 09:49 PM
so tis bad to run it without the t-stat ?
Old Jul 13, 2004 | 09:53 PM
Kentetsu's Avatar
Yeah, what they said. You can't rev hard on a cold engine, right? Without a t-stat, your engine will probably not get up to a high enough temp unless you are full out racing it. Keep it in so that your engine can run at the temp it is happiest with.
Old Jul 13, 2004 | 11:29 PM
Siraniko's Avatar
RX for fun
nope but it just takes longer to warm up....also, RB's recommendation of tapping the water pump by-pass only for track car, not street car.
Old Jul 14, 2004 | 03:04 AM
Hades12's Avatar
They say that with out something to block the bypass that it will burn up the engine. But I have not been able to find why they say that.
Old Jul 14, 2004 | 03:36 AM
Jeff20B's Avatar
Lapping = Fapping
The dumb answer is water will circulate inside the waterpump instead of through the engine.
Old Jul 14, 2004 | 07:51 AM
Siraniko's Avatar
RX for fun
here's a pix of a gutted t-stat.
Old Jul 14, 2004 | 02:43 PM
my t-stat that i pulled out..its missing a few things i think...but it runs so good now...
immanuel__7
89
Sep 5, 2015 10:23 AM
teamstealth
Oct 22, 2004 05:58 PM
KaiFD3S
Oct 13, 2004 02:09 PM
nycrx7
14
Dec 1, 2003 09:56 AM
