Perf Radiator ?: Koyo/Fluidyne/Mazda Motorsports....
Old Jul 8, 2004 | 04:16 PM
gnx7's Avatar
I'm building my car to be streetable but mainly focusing on tearing up the road race tracks here in Northern California.
I've tackled the following: suspension/wheels/brakes/driveline (425rwhp/400rwtq)
I now am looking to upgrade the cooling system.
SR Motorsports makes a 2" thick replacement radiator.... anyone running this?
Is the Koyo or the Fluidyne supposed to be better?
Lastly what about about the Mazda Motorsports unit?
Are the stock fans sufficient or do those need to be upgraded also?
Thanks in advance,
-Mark
Old Jul 8, 2004 | 05:37 PM
GT3_racer's Avatar
Radiator
I run a gt3 car in Texas and Oklahoma, it gets hot here and I had to duct off my radiator and oil coller because they were not getting warm enough on a 100 plus day, what did I use? a ADDCO racing radiator from a circle track shop, daul pass and fit great, at about 1/3rd the cost of the Mazda unit.
Old Jul 8, 2004 | 06:18 PM
John Magnuson's Avatar
The SR Motorsports Radiator is a relabled Koyo Radiator. Don't pay extra for the label.
Old Jul 8, 2004 | 07:33 PM
Silkworm's Avatar
Has been.. hangin' around
Koyo's not big enough IMHO
Look at having a Griffin custom setup for you, then fab brackets to mount it
PaulC
Old Jul 8, 2004 | 08:01 PM
Carl Byck's Avatar
Mad Man
Use the new AWR. (that is a period at the end of that sentence)...
Old Jul 9, 2004 | 01:01 AM
RX-Heven's Avatar
I'll blow it up real good
AWR supplies many of the Mazdacomp radiators. That or a griffin would be my choice.
Old Jul 9, 2004 | 10:51 AM
bond007's Avatar
Post quality not quantity
Anyone care to bring some tech to this besides just saying that model X is better than Y in practical experience? Explanations or data as to why? Avg cooling temperature differences between brands?
I'm looking for a good radiator to cool a track FD3S (no longer going to be a stock car, so it needs an aftermarket radiator).
Why would one 2" core radiator be better than another? The Fluidyne, IIRC, is not a 2", so compared to the Koyo, the Koyo would have better cooling capacity if all other variables were the same (provided the extra 0.5" didn't choke airflow or something like that)?
Parameters that I have found:
Size of core (well, can't do much about that if you want it to fit in a stock application)
Fin density (fins per inch, I guess if it looks "packed" then it is about as good as you can get)
Number of tube rows (most aftermarket upgrades are 2 row and thus thicker core)
What makes these other radiators better?
I'm looking at non-name-brand radiator with a 2-row 2 1/16" core. Why would a Koyo be better or worse than this?
Silkworm: approximate cost on the custom Griffin setup? Specs on the core?
GT3_racer: looked at double-pass, it won't be as easy to implement because of the plumbing location change...
Old Jul 9, 2004 | 11:00 AM
RETed's Avatar
Hey gnx7, are we talking about your FC or FD?
There are vastly different answers depending on which year?
-Ted
Old Jul 9, 2004 | 12:51 PM
bradrx7's Avatar
The key to proper cooling is ducting. I've piddled with this for years on track FDs and my current setup (Koyo, moved my PS line to a power steering cooler, removed AC condensor and completely fabricated NO LEAK ducting) works very well in Texas heat. I run 11-12psi boost and the water temps stay at 190-195 with oil temps around 200. Call 1-800-radiator, get a Koyo and do the ductwork.
Old Jul 9, 2004 | 01:55 PM
Silkworm's Avatar
I was running a 26x19 IIRC, it was too wide, and too deep to fit with the swaybar and battery. If the battery isn't an issue, 26x16 will work nicely, otherwise 24x16
You'll want to have them put 1.5" inlet/outlets on the passenger side, and a 5/8" heater bung on the lower side (unless you've blocked off your heater line)
Make sure to specify the sizes on inlet/outlet, as the standard comes with a 1.75" outlet on the bottom
Shouldn't cost that much, I think I heard something around 250.
The hassle will be mounting it, since it won't come with mounting brackets.
PaulC
Old Jul 10, 2004 | 01:11 AM
gnx7's Avatar
Thanks for the replies guys... I think this can be a good topic for many of us.
RETed- My FC is in RX-7 heaven. I'm building the FD all out now.
Paul (Silkworm)- If you cut the radiator supports I was able to fit a 27.5x19" Griffen $189 radiator in my FC. Not pretty... but functional. Allows a beefy 18" fan that will pull crazy cfm.
I would like to know the physics behind this one myself... I do plan to do some ducting to let no air past the heat exchanger and direct it fully thru it as nearly every dedicated race car I've seen has this setup. Small opening sealed duct up front that opens up to the nearly the full size of the radiator and seats. Basically a box in front of the radiator. This is on a Southwest tour car (NASCAR 600hp 358ci Ford) and on an SCCA full tube chassis Stang (Greg Picket's car).
GT3 Racer- Could you PM... I'd like to talk to you further about your setup. What fan (s) are you running?
TX guys should have some good input as they certainly aren't living in the North Pole during the summer!
-GNX7
Old Jul 10, 2004 | 10:44 AM
C. Ludwig's Avatar
www.lms-efi.com
I'm with Silkworm. Have it fabricated and save a couple bills. I had a Howe core custom fabbed for my ITS car and it came in around $250. Mine was pretty much a bolt in with custom hoses. Just take your time and measure it accurately and fitment shouldn't be a problem.
As far as performance, the core is a 2-row with 1" tubes. It's setup for double pass which is more efficient than a single pass. Pretty sure all the aftermarket rads are double pass anyway. Water temps are always right in the 210 area (with the exception of some high temps last weekend...guessing we had a bunch of air in the system). At any rate, DO NOT underestimate the cooling needs of a track car. Having said what I run, I would strongly recommend a 3-row core on anything, especially a boosted motor. A 3-row will not give an extra 33% of cooling but every bit helps.
As has been mentioned, ducting is all important. Seal the flow to the rad and get eveything else out of the way. Some form of extaction behind the radiator or at the back of the hood helps as well.
Fans won't make the system. If you're not getting cool air on the rad without a fan, the fan will not be able to pull cool air through it.
Old Jul 22, 2004 | 12:14 PM
cruiser's Avatar
Koyo is nice, but without proper ducting it's not doing its job.
Old Apr 3, 2006 | 01:13 AM
SmogSUX's Avatar
No money. No love.
Sorry about the thread ressurection, but has anyone seen the new Dual pass koyos? They look pretty promising, but I haven't seen anyone give their thoughts on it.
I have a Griffin Dual-row that I was going to get some custom brackets put on, but am not sure yet..
http://store.summitracing.com/partde...5&autoview=sku
Would the new Koyo be better? I know I can use the stock shroud with it which would be a plus..I have a Black magic fan that I was going to put on the Griffin as well. I use my car for daily driving and auto cross and Thunder Hill track events...It might become less of a daily driver once I buy another car.
Koyo seen here:
http://mazdatrix.com/b8.htm
Old Apr 3, 2006 | 11:24 PM
tims's Avatar
Do a search on aluminum radiators and a bunch of stock car shops can build a custom unit for about half the AWR or KOYO. I had mine built by Childress Racecars in North Carolina. Faxed them a hand drawing with dimensions and in a week I had my radiator. with shipping about $300. double pass and I have never had any overheating problems. AWR and Koyo are better if all the OEM systems are to be kept. AWR uses Ron Davis cores which are one of the best(maybe the best) but are not cheap.
Old Apr 3, 2006 | 11:58 PM
jgrewe's Avatar
GET OFF MY LAWN
If you need something to bolt right in go ahead and pay the top dollar. I'm suggesting the same thing a few other members already have. I found a used Addco radiator from a Chevy powered stockcar for $75. I cut one hose nipple off and moved it to the passenger side with the other one(it was a cross flow). Half way between the hose nipples I cut a slot in the end tank, shoved a plate into the slot and welded it all up. So now I have a deluxe double pass 4 core radiator for under $100.
Oil cooling should be your bigger concern.
Hit the swap meets and save some dough.
Old Apr 6, 2006 | 12:36 AM
t-von's Avatar
Rotor Head Extreme
I got a new custom made one that will cool with out any problems fro sale.
https://www.rx7club.com/20b-forum-95/pettit-banzai-20b-radiator-sale-523477/
Old Apr 6, 2006 | 01:32 AM
KeloidJonesJr.'s Avatar
strictly business
Koyo with an efan is the way to go.
Old Apr 7, 2006 | 07:17 AM
Speedworks's Avatar
is all of this based on aftermarket cores with thesame sieze core as standard or are we talking bigger? I'm going to have a custom one built as well but still debating about stock size core and thickness...
Old Apr 7, 2006 | 07:19 PM
tims's Avatar
I built mine with a core that was the size of the opening, which is about an inch wider. If you use a double pass(so both hose connections are on the same side) you wont have any cooling problems with the same size as stock. they custom guys will weld on the brackets and all you need to di is mount it to the stock location. a couple minutes of measuring and a couple phone calls is all it takes.
Old Apr 12, 2006 | 02:12 AM
Turbo23's Avatar
Panda Bear
Anyone who happens to know or has the AWR unit for a FC know the demensions? I want to know if a flex-a-lite fan measuring H-17.5 and W- 21.5 will fit the face, and not conflict with the upper hose connection
Old Apr 15, 2006 | 02:36 AM
Turbo23's Avatar
Panda Bear
I know one of you guys has one. lets go with the info
Old Apr 15, 2006 | 07:09 PM
tims's Avatar
the AWR unit is exact an replica of the OEM unit only with a slightly thicker core, so if it fits the stock radiator it will fit the AWR unit.
Old Apr 16, 2006 | 08:21 AM
Larz's Avatar
Potato Love
I use a koyo. Compared to stock it is huge. My temps have never went over 200 on the hottest of days on the street with the AC on. I haven't tracked my car, just auto xed. But it's worked well for me. I just had to shim up the Intercooler shroud a little so it didin't contact the fans.
Old Apr 16, 2006 | 04:22 PM
Speedworks's Avatar
Huge in the sence of thickness or is the core larger regarding lenght and width?
