02 woes again!
Old Jun 16, 2004 | 01:10 PM
IAN's Avatar
IAN
Rotary Reborn!
02 woes again!
I measured my o2 signal to ground. There is resistance. Also measured the sheilding to ground there is resistance.
So is this correct? I seem to be stuck at 4mv readings all the time like the 02 loop is no good.
Thanks,
O and the sensor housing to ground reads as well.
Any input.
Old Jun 16, 2004 | 01:18 PM
SureShot's Avatar
Seduced by the DARK SIDE
Sensor wire to ground at ECU should be .4 to .9 volts.
Old Jun 16, 2004 | 02:15 PM
IAN's Avatar
IAN
Rotary Reborn!
Is this at idle?
I measuring this with the car off and battery disconnected. I was just measuring ohms to see where it was grounded.
thanks
Old Jun 16, 2004 | 02:50 PM
SureShot's Avatar
Hmm - I have never ohm'd an O2 sensor.
Download the "fuel & emissions - NA" section of the manual & go to page 31.
There is a link to my copy in my sig below.
Old Jun 16, 2004 | 07:13 PM
IAN's Avatar
IAN
Rotary Reborn!
Not sure which link your talking about.
I measure the 02 body to ground. Below 1 ohm. Measure 02 body to sensor wire below 1ohm which looks like this should not be so.
I never measure voltage during idling etc. I will have to check this out later.
Thanks
Old Jun 16, 2004 | 08:07 PM
rs_1101's Avatar
will higher resistance cause richer running car?
93rx74lyfe
SE RX-7 Forum
11
Feb 14, 2008 05:55 PM
M104-AMG
Jan 27, 2007 05:08 PM
DemonicPupil
Jun 12, 2006 05:45 PM
vaughnc
21
Jul 11, 2002 04:31 PM
