where can I find this tool?
Old Jun 14, 2004 | 09:32 AM
fong's Avatar
Question where can I find this tool?
hi, trying to tear down the engine, and the flywheel won't come off with bar. FSM says to use special tool (SST) to pull it out. that looks like a puller to me. but where can I find it. I can't find it in couple of local stores.
any suggestion to find this puller? this is the last thing I need to resolve.
thanks
Old Jun 14, 2004 | 09:35 AM
Relisys190's Avatar
REINCARNATED
Check your local Mazda dealer. Unfourtunatly it is not an item that can be rented. If you have a local rotary shop in the area they may let you "borrow" their tool but not likly.
Good luck in your quest!
Regards,
-Markus R.
Old Jun 14, 2004 | 09:48 AM
SonicRaT's Avatar
Super Raterhater
If you've got the flywheel bolt off, just smack around the outer edge with a mallet, it'll come off. Screw the flywheel pullers!
Old Jun 14, 2004 | 09:53 AM
Relisys190's Avatar
REINCARNATED
That's true too... If the large bolt is allready removed just hit the sucker with a mallet. lol.
Regards,
-Markus R.
Old Jun 14, 2004 | 10:00 AM
JerryLH3's Avatar
Rabbit hole specialist
Make sure the bolt is loose, but leave it on a couple of turns. It would really suck to have the flywheel dropping on the floor, your foot, your head, etc. Then once the flywheel is loose from tapping with a mallet, take off the bolt, and pull of the flywheel.
Old Jun 14, 2004 | 10:14 AM
fong's Avatar
thanks for all the suggestion. I have tried with pryer bar, and hammer, and no luck. and I spry WD40 also. the damn wheel just won't come off.
so, no puller from auto stores will work, except from dealer?
Yah, Jerry, thanks for the suggestion. I should keep the bolt on to prevent any damage to my toe from the flywheel. :-)
Old Jun 14, 2004 | 10:18 AM
Josepi's Avatar
Despise Enmity
I used a 17" pry bar from sears, putting the tip near where the flywheel/eccentric shaft meet and putting a load of pressure on it. Turned the flywheel, repeat. It popped off after 6 times for me.
That was the only way I got mine to come off after struggling with it for 5 hours using everything from mallets to a propane torch.
Old Jun 14, 2004 | 10:21 AM
powrdby13B's Avatar
i'll blow YOUR valve off
hey speaking of, I've been doing a motor swap for a week or two (i had to go out of town... was sposed to be done before i left, and i just got back OUCH) and the first motor separated from the tranny really easily. This motor is a real PITA! I have a motor hanging from the ceiling of my house and I also have a car hanging from the house. How do I get the engine out of the tranny, step by step? Do I need to take any gears off for sure or what? Like i say, the last one came out WAY TO EASY and this one is A BITCH.
Old Jun 14, 2004 | 10:40 AM
White 87 13B's Avatar
pita...HAHAHA
Old Jun 14, 2004 | 10:41 AM
powrdby13B's Avatar
oh, cmon this is a simple question for most cars... im just stupid and i need it done ASAP and i dont have time to figure out how... do i disconnect the flywheel from the tranny? do I rip until it comes out? do i remove the shaft before the flywheel somehow? cmon...
PITA lol i stole that from somebody else hehe :-D glad u liked it
Old Jun 14, 2004 | 12:16 PM
powrdby13B's Avatar
bumparoony...
Short version: removing engine from car. Won't let loose of tranny. What do i do?
Old Jun 14, 2004 | 12:24 PM
hIGGI's Avatar
Originally posted by powrdby13B
bumparoony...
loose all bolts and make sure engine to transmission is always in level
Old Jun 14, 2004 | 12:26 PM
powrdby13B's Avatar
that would include the 6 bolts on the flywheel?
Old Jun 14, 2004 | 12:27 PM
hIGGI's Avatar
no, flywheel stays on the engine if u are separating engine from transmission
Old Jun 14, 2004 | 12:42 PM
powrdby13B's Avatar
htf do i get it out then? theres like 2 or 3 bolts that attach the engine to the tranny... what do i do?
Old Jun 14, 2004 | 12:44 PM
hIGGI's Avatar
there are 2 bolts on passenger side and 2 bolts on drivers side (plus 2 starter bolts)
Old Jun 14, 2004 | 01:15 PM
powrdby13B's Avatar
never mind. im a retard. its out.
DerpyToast
14
Nov 23, 2024 05:19 PM
Jmolina0163
Oct 3, 2015 10:04 AM
rafgonz
Sep 7, 2015 06:36 AM
Apoc3D
Sep 5, 2015 10:24 AM
