Microtech 400+ hp Microtech Club - Whos In It?
Old May 29, 2004 | 06:02 AM
silverrotor's Avatar
Arrow 400+ hp Microtech Club - Whos In It?
I'd like to think I'm Initiating my way In there as I'm waiting for everything to tie In together...slowly, but surely.
Who's In It? What Microtech are you running and details of your setup would be great.
Let's hear of the 400+ hp Microtech RX-7's.
Old May 30, 2004 | 03:12 AM
Not many, eh?
Old May 30, 2004 | 07:37 AM
banzaitoyota's Avatar
What Subscription?
I switched to an E6X.
Old May 30, 2004 | 10:15 AM
kong13B's Avatar
Newbie
Hey me but I live in Thailand.got hp around 450 rwhp
Old May 30, 2004 | 12:54 PM
Sounds Interesting kong13B. Can you give us details/pics?
Old May 30, 2004 | 01:04 PM
pianoprodigy's Avatar
Missin' my FD
410 RWHP 311 TQ at 16 psi with T66 (See Sig)
http://www.alantripp.com/410DYNO.jpg
Old May 30, 2004 | 06:28 PM
t-von's Avatar
Rotor Head Extreme
WOW how well does the engine perform in the 12's for your A/F ratio? Any major signs of knock? I've never seen an A/F curve that flat and level in the 12 range
Old May 30, 2004 | 07:44 PM
10sec rx7's Avatar
i made 463 rwhp at summernats,
setup is
LTX12
t66
2x550 and 4x1200cc injectors
s4 turbo block
s4 turbo box
9in diff,
Pump fuel
tuned by Jon (rxeng), myself and project-x
new setup is
LTX12s
gt42
2x800cc and 4x1600cc injectors
bridge port (rxeng)
ford toploader with liberty dog gears
9in diif
looking to make 620+rwhp and low 9sec 1/4 mile
Dale
Old Jun 1, 2004 | 12:14 AM
bcty's Avatar
Boost This!
i was there with the old setup on E6K but im switchin to Microtech after this last engine blew..
T66ish size turbo
4x720cc (should put me right around at the 400mark)
S5 block
Mild port
walboro
S5 box
Old Jun 1, 2004 | 02:06 AM
I'm applying for membership, new streetported engine, ported twins, downpipe w/high flow exaust, LT12 Microtech, custom v-mount, and Apexi intakes. Rx6b turbo later. All this on an automatic FD.
Matt
Old Jun 2, 2004 | 12:17 PM
You know you never have to pay......just dyno sheets Is a prerequisite.
Old Jun 2, 2004 | 07:54 PM
Forcus's Avatar
For you few with 400+ HP, how is driveability?
Old Jun 2, 2004 | 11:16 PM
Missin' my FD
I've been driving it for almost a year tuned that way and have had no problems at all. I run 13 psi on 93 octane and 16 psi on 100 unleaded.
Old Jun 3, 2004 | 11:18 AM
FD Rey's Avatar
I brake boost
I'm planning on getting there. I'm not sure how much boost I'd have to run on my little 60-1. I am about to put in my 1600cc injectors, fuel pressure regulator, and put my 850s as primaries. I'm on stock ports too.
Old Jun 4, 2004 | 05:36 AM
Rx_treme's Avatar
I prefer Haltech after hacing tuned and installed a Lt8 however here's a dyno chart from my friends T2.
T70
Street port S4 block
Greddy 32r fmic
Microtec lt8
720/1680cc
etc
http://www.idahorotary.com/dyno448.jpg
110 advanced timing 19 psi dropping to around 16 and toooooo much fuel..
J
Old Jun 5, 2004 | 09:10 PM
12at's Avatar
10.21 @ 137mph
I made 480 rwhp
Set up is:
12a turbo block (bridgeport)
LTX8
13bt inlet and throttle body
2 x 800cc and 2 x 1700cc injectors
s4 gearbox
Hilux diff
I have a dyno sheet but need someone to host it.
Old Jun 8, 2004 | 04:09 AM
HIMNI Racing's Avatar
Rick James
I don't want to post under somone that made 480 but..
I made 300 at 12 psi....ran out of fuel = (
LT8
street ported S5 TII
T04B
2- 720's 2-860's
and all the other junk.
I'm dropping in a pair of 1600's right now and going to try and squeeze 390-400 out of the to4b before I go 60-1 hi-fi. That should push it to about 18-20 psi before the t04b falls flate = )
Oh yeah, I drive the car every day.
Old Jun 9, 2004 | 06:17 AM
rxeng's Avatar
I've done at least 100 of them!!!!!!
Not all in RX7's but all are 12A or 13B engines (with a few 20B's in there too).
I also have need a membership in the 500hp,600hp & 700hp at the wheels club too!!!
All with Microtech!!!!!!!!!!!!
Old Jun 9, 2004 | 11:02 PM
WestJaxVert's Avatar
LT8
T04B
2- 720's 2-860's
How the heck did you run out of fuel? I was running a TO4E at around 12-13psi with 550's and 850's and had no problem.
Dan
Old Jun 10, 2004 | 11:50 PM
Rick James
Dan
They were at about 73% (41 psi base press. with a RRFPR) and Rolo said any more isn't good. I always tought 80 was OK but who in there right mind would go against what Rolo suggests? After 25 years of tunning the MT and seeing him pull a extra 60 HP out of the engine, with almost not even looking at the hand controller....
I'm going back this SAT. so he can play with it more
Oh, remember that a t04b will out-flow a t04e
Old Jun 11, 2004 | 08:49 AM
I thought 85% was OK, but then again, I've heard nothing but good things about Rolo, so...
Good luck.
Hmmmm...I always thought that was the other way around. I guess I learned something new today.
Dan
Old Jun 16, 2004 | 02:37 PM
LT8TurboII's Avatar
T04B will not outflow a TO4E, a 60-1 wheel in a t04b housing will outflow a smaller T04E, and a 60-1 wheel in a t04e housing will flow even more....
Old Jun 24, 2004 | 03:08 PM
Ryde _Or_Die's Avatar
I want to be in, just have to get the MT in this summer and pick a turbo. In all honesty it will probably be next year before its done.
Old Jul 3, 2004 | 11:35 PM
stevecod's Avatar
i'll be there as soon as i get my GT40R. I'm running the LTX8S unit.
can't wait!!
Old Jul 8, 2004 | 10:17 PM
All The Time's Avatar
Newbie
measly 320rwhp
I hit 318 at the wheels in my 89 S5, so i guess that's about 400 at the flywheel...see sig for specs. But my battery recently blew up and the moron who installed my lt8 didn't put in an inline fuse. So now i'm upgrading to an LTX12, hopefully that'll help a little and it'll give the option of upgrading a a 20B later
