Rx7 Drive shafts
Old Mar 23, 2004 | 02:29 PM
Kill No Cone's Avatar
Rx7 Drive shafts
Hello Folks,
I have a friend who has an auto 85 Rx7, with a bad drive shaft.
Will a drive shaft from a stick work for the auto car?
Would a GSL-SE drive shaft work?
Any thoughts?
Thanks
Old Mar 23, 2004 | 06:02 PM
CrazyJoe12a's Avatar
The auto driveshaft is quite a bit shorter. No manual driveshaft would work. I have a good one in my garage, but he would probably be better off taking his to a driveshaft shop and having the U-joints replaced...
Old Mar 23, 2004 | 06:08 PM
C'mon someone must know...
Old Mar 23, 2004 | 06:10 PM
The automatic driveshaft is quite a bit shorter than the manual ones. I have a good auto driveshaft sitting in my garage, but he would probably be better off just taking his to a good driveshaft shop and have them replace the U-joints.
Old Mar 23, 2004 | 06:17 PM
inittab's Avatar
I read your email
Old Mar 23, 2004 | 06:21 PM
wagondriver69's Avatar
Old Mar 23, 2004 | 06:53 PM
peejay's Avatar
Old [Sch|F]ool
For any consolation, if it was a '83-earlier automatic car a manual shaft would work.
The difference is the '84-up had 4 speed autos, which were longer because the 4 speed is just a 3 speed with an overdrive unit sandwiched between the bellhousing and the rest of the trans. Added length means shorter driveshaft.
Old Mar 24, 2004 | 01:32 AM
Thanks for the info on this, I will relay the info.
Thanks again
Azevedo
26
Mar 1, 2019 09:19 PM
rx7jocke
Aug 15, 2015 03:36 PM
LMBTG
Aug 15, 2015 01:43 PM
ncds_fc
Aug 15, 2015 10:06 AM
