FC Buying Question
Old Oct 21, 2001 | 01:40 PM
RyanC's Avatar
FC Buying Question
A friend of mine is looking to get an FC for his second car to take some miles off of his ITR. I am pretty much an FD guy and know everything to look for when it comes to them, but I don't know much about the FC. I am planning on looking at some cars with him and I want to know what kind of things you should look for when buying an FC. Thanks.
PS: If this question has been asked a million times I am sorry. I did a search and I didn't find a whole lot though.
Old Oct 21, 2001 | 03:26 PM
JerryLH3's Avatar
Rabbit hole specialist
Typical problems:
1 - Wiper switch difficulties. They will probably only work in certain positions and not others. Fixes include replacing relays in the switch (with varying degrees of success) or finding one that will work off a parts car (also with varying degrees of success).
2 - Flooding problems. Could be owners fault for not letting car warm up, or could be a sign of other problems (like leaky injectors).
Otherwise just check for basic things you would on any car. How does it run? Does it shift well? Any notchiness when shifting? Rust? Is it clean - inside and out?
Old Oct 21, 2001 | 05:32 PM
Crusader_9x's Avatar
look for everything that has an electrical switch in it. the logicon/heater unit for example.
check Http://www.teamfc3s.org
and Http://www.johnr.com here follow the rx7 links and it will take you to a prety good common probllems list
Old Oct 21, 2001 | 06:56 PM
rotorhead1's Avatar
obviously the first thing to check is compression, especially on high mileage cars. yes, the fc is an older car now, and everything electrical has the chance of having a quirk or two.
Old Oct 21, 2001 | 06:59 PM
RyanC's Avatar
Thanks
Old Oct 21, 2001 | 10:27 PM
Ryde _Or_Die's Avatar
For a daily beater just look at mileage & compression. If you are pretty much set on the car, might want to change the oil & see what that looks like. You can tell if its been running a while without a change usually.
Old Oct 22, 2001 | 02:10 AM
Taris_Blue's Avatar
Daily beater??? HOW DARE YOU!!! LOL -Taris Blue
Old Oct 22, 2001 | 02:19 AM
ItsNiceToBurnRice's Avatar
What the hell?
Ive had an rx7 for 2 days, and I see this alot. What the hell is a FC and a FD, or what does it stand for? Forgive my stupidity.
Old Oct 22, 2001 | 02:38 AM
snoopster76's Avatar
Twisted Girl Chaser
fc=2nd gen
fd=3rd gen
it is the first two alpha numerics in the vin #
Old Oct 22, 2001 | 03:11 AM
Thanks i needed that
Ah yes, that makes sense, thanks for informing me. now i only have 999,999 things to learn instead of a mill.
hotshot2014
Jul 18, 2017 02:30 PM
vipernicus42
Mar 7, 2016 04:57 AM
vipernicus42
Canadian Forum
Sep 5, 2015 09:37 AM
c0rpse
Aug 25, 2015 11:50 PM
